Tpms reset button?
Old 04-13-15, 08:42 AM
Striker98
Striker98's Avatar
Default Tpms reset button?
Hey guys. So I'm just putting my summer wheels back on and I ran my winters without sensors so had the light ect. When I put the summers back do I need to reset the seniors or will they just automatically pick back up again once I drive? I see in the manual there is a reset button under the dash but I just been under there for 20mins and for the life of me can't find it.
Thanks
Old 04-13-15, 09:06 AM
Answer
Answer's Avatar
Everything should be back to normal once the sensor are back on the car.
And just FYI, the reset button is pretty far near the brake pedal under the dash.
Old 04-14-15, 10:11 AM
cFoo
cFoo's Avatar
Were you able to get the reset button to work? I followed the instructions in the manual and it did nothing. I'm still stuck driving with the light on. I don't understand why they wouldn't allow 2 sets, especially on an AWD car with all the cold weather features. It's such a pain in the butt, even a cheap Honda Fit from more than 5 years ago support 2 sets of sensors.
Old 04-14-15, 11:00 AM
AndyL
AndyL's Avatar
It used to support two sets of sensors for the 2nd gen IS and later, Lexus has decided to change it to just a reset button. Reason that I have heard is some issues with two sets as it got confused sometimes.
Old 04-14-15, 03:01 PM
Striker98
Striker98's Avatar
No I couldn't find the button. But after filling them with air and driving for 10mins the car found them again and my light went off.
Old 04-14-15, 03:54 PM
cFoo
cFoo's Avatar
http://drivers.lexus.com/t3Portal/do.../sec_07-03.pdf
Page 413. You have to push the seat all the way back, get under the dash. There are 2 small buttons, the one on the left is the one you want.
Mine continuously blinks when the ignition switch is on so I don't even know if it should stay constant on or not. Holding the reset button doesn't cause it to blink any slower so I can't tell if it's working or not. I tried it anyway and it did absolutely nothing.
It's BS that having two sets will confuse it sometimes. I've had two sets in my dad's MDX, my wife's RDX, and my old Honda Fit commuter for years without any problem. It either works or it doesn't. All the ECU has to do memorize the location and the sensor's ID. Store 2 IDs in one location. They're either lazy or they cheap out and bought a cheaper ECU from the supplier.
Old 04-29-15, 04:45 PM
jkwiseeyes
jkwiseeyes's Avatar
Default Found it!
Under the dash behind the centre of steering wheel.
Lexus IS250 AWD 2014
Cheers
The following 2 users liked this post by jkwiseeyes:
LexoticJ (09-15-20), MAXXXICE (12-09-20)
Old 04-29-15, 07:17 PM
Mushi31
Mushi31's Avatar
What does the Reset button do, in the manual it says we would need to inflate our tires and then press the button and then fill it up with air? What are the exact steps for reseting the tpms sensors? Please explain. Thanks again in advance!
Old 03-30-20, 11:45 AM
LexusE350
LexusE350's Avatar
Default 2015 Lexus IS250 FSport - How do I reset the TPMS system
Wondering if anyone can help me with this? The model does not have a reset button that I can locate?
Thank you.
John
Old 03-30-20, 04:33 PM
dizlex
dizlex's Avatar
Yes, it was a STUPID f'ing decision from Lexus. Seriously, they should get their heads examined. Idiots.
Old 03-31-20, 07:04 AM
Sasnuke
Sasnuke's Avatar
Received 1,732 Likes on 1,368 Posts
Thank you.
John
The pic two posts above is the location of the button on the IS. All 3IS have a reset button inthe same location.
To give you some reference points in the pic...the OBD II connector is to the left of the button, if you turn your head sideways to the left.
The green item you see below the button is part of the parking brake pedal assembly.
The white ducting to the right of the button is the foot vent for the driver.
Hopefully that narrows it down to where the button is located.
MAXXXICE (12-09-20)
Old 04-07-20, 10:10 AM
LexusE350
LexusE350's Avatar
Thank you for the info. All is working great!!!
tanstaafl
ES - 5th Gen (2007-2012)
03-16-19 04:10 AM
pacmanmmc
06-28-16 06:54 PM
Cardo111
ES - 6th Gen (2013-2018)
02-08-16 05:40 PM
dlap
04-08-12 07:58 PM
vancouverl
12-24-10 01:20 PM
Quick Reply: Tpms reset button?
