So on Tuesday im planning on adding some spacers to my ride to wide it out a bit, however I am currently on 255/30/20 rears w/ Vossen CVTs 20x10.5 and 225/35/20 fronts w 20x9, how much if any can I space it out?, the rears look so snug already do you guys think i will be able to wide it out more without rubbing? if so how many mm?
I don't think you have any space in the back, there's no rear camber adjustment. And the fronts would probably rub unless you cambered out quite a bit if you add any significant spacer
