is350 rpms go to 1500 when put in park
Old 03-10-15, 01:32 AM
is350in253
is350in253's Avatar
Default is350 rpms go to 1500 when put in park
Hello there new to the forum
i own a is350 been having this problem
i drive the car get home put it in park and rps go to 1500 and stay there feels like my idle stays high any help would be great thank you
Old 03-10-15, 05:24 AM
AdvanSLF
AdvanSLF's Avatar
yeah that doesn't seem right, usually idle is at 800 or lower.. i would get that inspected soon. its common for it to idle around that range or higher when its a cold start.. but you mentioned once you returned home so the car would have been warmed up and the idle should sit lower.
Old 03-10-15, 08:47 AM
drbazing
drbazing's Avatar
I'm assuming it's not throwing any codes. I'm going to throw vacuum leak as my first guess. Get it checked OP.
Old 03-10-15, 06:54 PM
IFRPilot
IFRPilot's Avatar
Sounds like a cold start - itll hold it there for a while.
No check engine lights, nothing to really check out. Vacuum leaks trigger real time / stored gross evap leaks. It is all computer controlled and does what it needs to do.
Old 03-10-15, 09:42 PM
scarboy693
scarboy693's Avatar
Yea it does that in colder temperatures. Mine does it too.
Old 03-10-15, 11:08 PM
Larry96815
Larry96815's Avatar
Mine never does that.
Old 03-17-15, 07:47 PM
is350in253
is350in253's Avatar
Default sorry for the late response
Sorry for the late response, there is no codes at all,havent got around my vaccum houses im going to inspect them tomorrow,just did my spark plugs,oil change, F sport air filter and clean the MAF but still same
Thank you every one for the fast response
Old 03-18-15, 07:24 PM
Loe
Loe's Avatar
what about using the warranty?
Old 03-18-15, 08:56 PM
BOBFSPORT
BOBFSPORT's Avatar
1500 is completely normal in cold temperatures.
Old 03-18-15, 09:13 PM
rp2000r
rp2000r's Avatar
If it helps I have the same car in WA and mine does not do that...
I would have the dealer/warranty take a look.
Old 03-18-15, 11:16 PM
BOBFSPORT
BOBFSPORT's Avatar
No this isn't my car but look at the rpms.
Old 03-19-15, 06:10 AM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
Is this on the '06 IS350 listed in your profile? If so, you may consider asking this question in the 2IS forum. Granted we have the same engine in the 3IS, but you'll find higher mileage examples and people with more experience with the engine in that forum.
Old 03-19-15, 06:36 AM
rp2000r
rp2000r's Avatar
Temps in WA have been above normal, 55-60 degrees most days, My 15 350 was sitting for a week and I drove it last night. Idle at 800 after warmup, came home, put her in park, idle at 800.
If cold out Iam sure it goes into cold start mode but after warm up should be fine.
Old 03-19-15, 07:18 AM
NYKnick101
NYKnick101's Avatar
If the car is still cold and not fully warmed up it will idle at hire than 1000. I have a 2IS and I could drive to the store on a cold start (when i am in a rush) and when I put it back in park it still idles at 1k-1200 rpms. Doesn't really drop until its really warmed up.
Question to the OP is does it do this after its fully warmed up or just after getting into the car and driving. Not Temperature outside warm but Oil temp in the middle warm
LamTheSham
12-19-23 04:11 PM
dentroAuto
12-05-18 03:49 PM
DKKis350
01-23-11 11:08 AM
socal72
SC- 1st Gen (1992-2000)
27
12-01-10 10:27 AM
gologic
12-13-05 08:45 AM
Quick Reply: is350 rpms go to 1500 when put in park
