Stereo input/Amp output wiring
Old 02-10-15, 08:18 AM
  #31
Loe
Loe's Avatar
yes....i used to sub out lines.
Old 02-10-15, 06:26 PM
  #32
Fingers007
Fingers007's Avatar
Yes, sub out lines worked for me. I now have more bass than I know what to do with.
However, sub out lines are still not turning on the LC2 with GTO enabled.
Old 07-10-15, 06:01 PM
  #33
slonline
slonline's Avatar
Hey guys, I see that this is an older thread and I don't see the wiring diagram to the amp that is mentioned. May be it has been remove due to age. Any one still have a copy that you can repost? I want to tap in a sub (preferably before the sign got to the amp), so hoping someone can help me.
2014 IS350, premium sound system, but non ML system.
Thanks.
Old 07-10-15, 06:11 PM
  #34
Loe
Loe's Avatar
The signal preamp is too weak, im actually surprised how well the OEM amp/speakers sound as decent as they do; sound quality is much better post amp.
Old 07-10-15, 06:18 PM
  #35
slonline
slonline's Avatar
Leo, thanks for your feedback. Do you happen to still have the diagram?
Old 07-11-15, 06:39 AM
  #36
Smitty17
Smitty17's Avatar
I would be interested in this diagram as well
Old 07-12-15, 10:03 AM
  #37
Fingers007
Fingers007's Avatar
Hey Team, I still have all the pics and docs I got from Loe.
Old 07-12-15, 10:08 AM
  #38
Fingers007
Fingers007's Avatar
Here are the docs i got from Loe. Thanks Loe!!!
File Type: pdf
File Type: pdf
Old 07-12-15, 11:42 AM
  #39
Smitty17
Smitty17's Avatar
Thank you
Old 07-13-15, 01:31 PM
  #40
shirosan
shirosan's Avatar
Thanks for the post! What wire did you use for the remote (on/off) connection? I'm sure we can tap one from the OEM amp and send it to the aftermarket amp. Thanks!
Old 07-13-15, 02:58 PM
  #41
specONE
specONE's Avatar
best to grab Remote wire from factory Cigarette Lighter port and run that to the rear of the car.
Factory Amp does not have a standard 12v analog signal turn on, its all through data.
Old 07-14-15, 10:54 AM
  #42
Fingers007
Fingers007's Avatar
I tied my remote wire to the "ignition 3" fuse under the driver side dash. This fuse is only active when the car is on.
Old 07-14-15, 08:36 PM
  #43
specONE
specONE's Avatar
Here's a clean PDF off of TIS of the full wiring diagram for anybody else in the future.
https://drive.google.com/file/d/0B-a...H4U3J9yNzA65bw
The following 2 users liked this post by specONE:
BOFF456 (04-24-21), CriMe (05-31-18)
Old 07-15-15, 07:58 AM
  #44
shirosan
shirosan's Avatar
Awesome, thanks for the heads up too.
https://drive.google.com/file/d/0B-a...ew?usp=sharing
I will have to try this link once I get home from work. Darn work loves having proxy problems all the time haha.
Old 08-12-15, 07:53 AM
  #45
No0dLeZ
No0dLeZ's Avatar
Thanks for the share!
Quick Reply: Stereo input/Amp output wiring
