Aftermarket subwoofer setup?
#32
How hard is it to install something like this to an 3IS with ML ? (or without ML) ?
#34
#36
How hard is it to install something like this Amazon.com : Infinity Basslink 200-Watt, Dual 10-Inch Powered Subwoofer System (Black) : Vehicle Subwoofers : Car Electronics to an 3IS with ML ? (or without ML) ?
#37
Can definitely tell the difference when you tap into the stock sub line with the lc2.
Sometimes the sub doesn't play certain bass lines. Sometimes it's also a little bit delayed. It's not terrible, but noticeable.
I'm also thinking that the processor distributes a little more power to the front speakers too. Which is great for what I was shooting for.
Another thing to note.. If you plug your phone into the USB port in the center console, the bass is twice as loud as using Bluetooth. Some music sounds better plugged in, some sounds worse.
The new enclosure setup is actually so loud that it shakes a lot stuff inside and sounds bad at times. Not really sure that dynamat would fix it.
#38
You're probably experiencing bass run off. adjust the accubass. The thing I don't like about plugging into the usb port is it gets cut off sometimes if the bluetooth is on. There should be a recall or something!!! A couple of posts about it.
Dynamat will help a lot but gets pricey. I have a JL and it sounds just right. clean bass and no need for dynamat!
#40
#41
Stay tuned guys ..... I'm gonna be doing a custom trunk setup with Memphis audio all around including my accuair set up , so more to come , if you wanna see my progress follow me on Instagram @erickf8276
#43
