General LED - Resistors/Flasher question
Old 11-08-14, 03:36 AM
Sandeman
Sandeman's Avatar
Default General LED - Resistors/Flasher question
Wondering if you guys could shed some light on this LED question (i used the search feature but wasn't able to find an answer to my question )
Im looking to replace the interior lights with LEDs (map lights, puddle lights, floor etc) do the 3IS need resistors in order to draw the correct load and NOT throw a bulb out light/not work at all?
I have this concern because I previously owned an Audi and everything needed to have a resistor.
I know HID Powerhouse carries the full kit but I'm looking for some other options.
thanks in advance!
Old 11-08-14, 02:02 PM
Imprezario
Imprezario's Avatar
No need for resistors, just plug and play )
Old 11-09-14, 08:37 AM
leoben
leoben's Avatar
So we don't need canbus led lights? I mean, there's no check in our IS and we don't need the "no error" version of the led lights?
Old 11-09-14, 10:47 AM
HIDPH
Former Sponsor
HIDPH's Avatar
The 2014+ Lexus IS does not require CAN-BUS compatible LED bulbs.
Feel free to send us a private message or email us if you have any questions!
Old 11-09-14, 10:50 PM
Imprezario
Imprezario's Avatar
Unlike Germans, Toyota/Lexus cars do not have onboard diagnostics of bulbs, i. e. do not monitor resistance of them. So if You replace bulbs with LEDs, the jananese car doesn't "feel" the replacemen => no checks or errors )
Old 11-10-14, 07:35 AM
Sandeman
Sandeman's Avatar
thanks to all that contributed!! greatly appreciated!
Old 11-10-14, 03:00 PM
Jlin89
Jlin89's Avatar
what if you're replacing turn signals? will there be hyper flash without an led flasher unit/resistors?
Old 11-10-14, 03:05 PM
HIDPH
Former Sponsor
HIDPH's Avatar
For the front and rear turn signals, you will need resistors to correct the blinking speed when you upgrade to LEDs.
We offer a plug and play resistor kit that will allow you to install the LED turn signals without splicing / tapering the factory wiring.
Old 11-10-14, 08:30 PM
Sandeman
Sandeman's Avatar
was just about to ask that once i noticed the hideous orange that the lights omit when they aren't in use
thank you you've been tons of help
Old 11-11-14, 04:59 AM
plastus
plastus's Avatar
How hard is it to replace the LED turn signals on the front/rear of the IS? I remember with my previous car it required removal of windshield washer reservoir, some plastic trim, etc. before one could get their hand into the world's smallest headlight cluster access panel.
Old 11-11-14, 06:41 AM
Imprezario
Imprezario's Avatar
For F Sport You do not have to remove anything for changing the front turn bulbs. For rears You'll have to remove the whole tail light from the fender.
Old 11-11-14, 07:43 AM
plastus
plastus's Avatar
Bummer...so the 2IS method of removing the trunk liner and just accessing the bulb socket won't work?
Old 11-11-14, 07:51 AM
Imprezario
Imprezario's Avatar
Nope. No access from inside.
Old 11-11-14, 07:54 AM
plastus
plastus's Avatar
Ok, thanks for the info. How easy is it to remove the taillight to replace the turn signal bulbs?
Old 11-11-14, 11:40 AM
Sandeman
Sandeman's Avatar
Can anyone confirm the proper bulb size for the front and rear turn signals? I'm getting 7444 from all my searching
Quick Reply: General LED - Resistors/Flasher question
