General LED - Resistors/Flasher question
Old 11-11-14, 11:44 AM
TTechLexus
TTechLexus's Avatar
Originally Posted by Sandeman
Can anyone confirm the proper bulb size for the front and rear turn signals? I'm getting 7444 from all my searching
7440 size bulb
Old 11-12-14, 02:52 PM
Imprezario
Imprezario's Avatar
Originally Posted by plastus
Ok, thanks for the info. How easy is it to remove the taillight to replace the turn signal bulbs?
Just remove two screws under small plastic covers (You'll see them when open the trunk) for each tail light and then gently remove the whole light from the fender only with hands, no tools required. This way You'll get access to the bulb inside the removed part. Masking the fender area near the tail light with tape is recommended, because it's easy to scratch the paintwork when removing/installing the light. The manual describes this procedure clearly )
Old 11-12-14, 03:23 PM
plastus
plastus's Avatar
Thanks for your help! Appreciate it.
ahynot
11-08-21 06:57 AM
Masteron
GS F (2016-present)
04-14-16 07:40 PM
mbz560
10-23-12 11:04 AM
Baybarea
08-12-11 03:39 AM
Booyah
GX - 1st Gen (2004-2009)
11-28-10 07:32 PM
Quick Reply: General LED - Resistors/Flasher question
