Having sames size wheels on 350 f sport
Old 10-25-14, 05:10 AM
silvaIS
silvaIS's Avatar
Default Having sames size wheels on 350 f sport
I am trying to find out if it would be ok to have the same front wheels as we have on the rear.
I don't know if its a fitment or performance issue, I would make my life easier so I can rotate the tires
Old 10-25-14, 08:15 AM
Logansrun2
Logansrun2's Avatar
I also would like to do the same
Old 10-25-14, 08:20 AM
criticalgt
criticalgt's Avatar
They will fit as long as you can find them....
Old 10-25-14, 11:14 AM
silvaIS
silvaIS's Avatar
so no issue with using the same size we have for the rears on our front as well
Old 10-25-14, 11:19 AM
criticalgt
criticalgt's Avatar
no the difference is very minimal in width and offset
Old 10-25-14, 06:01 PM
JustNoize
JustNoize's Avatar
350 F SPORT Rears DONT Fit On Front.. Found out the Hard Way when i got a flat on the front wheel and tried to bring the rear tire to the front so i wouldn't have a donut for steering ..
Old 10-26-14, 08:18 AM
Hermes
Hermes's Avatar
I had a difficult time finding winter tires that would have the same tread in the front/back because the wheels are staggered. Most of my options were performance winter tires.
Also found out, since we can't rotate our tires with OEM wheels, the warranty is dropped to 25,000km instead of 50,000km...
Old 10-26-14, 08:37 AM
criticalgt
criticalgt's Avatar
Why wouldn't they fit? Do they not clear the calipers?
Either way, swapping the tires on the wheels after two or three seasons will cost you no more than $100.
235/40/18 will fit nicely on 8" and 8.5" wheels. 245/40/18 is also an option...
Old 10-26-14, 10:40 AM
wthrman2
wthrman2's Avatar
Received 3,589 Likes on 1,752 Posts
It sucks that they are using different sizes.
Old 10-26-14, 01:25 PM
CJW
CJW's Avatar
There is a suspension piece on the inside that won't clear. I measured as best i could and 9mm was about the clerance from the OEM front wheel to the piece. The lip of the rear tire will touch this peice if you try to put a rear wheel on the front.
I'm guessing *maybe* a narrower tire might fit with the rear rim, but it just needs less offset.
Just have a quick look and you can see it pretty easily.
Old 10-26-14, 08:34 PM
criticalgt
criticalgt's Avatar
....or 15mm spacers I guess
BED72055
01-08-17 06:46 AM
Celledral
10-18-16 01:47 PM
13GS
Wheels, Tires & Brakes Forum
01-19-16 02:48 PM
UncleSpud
11-25-13 11:56 AM
Quick Reply: Having sames size wheels on 350 f sport
