does aftermarket cold air intake void any warranty?
Old 10-08-14, 11:52 AM
Hermes
Hermes's Avatar
Originally Posted by Larry96815
Wrong holes. Two holes cool brakes, two do nothing. Lexus even makes a fog light kit to mount in those two holes. Use those holes for CAI instead of fog lights. Look close and you will see they already have a small hole far back inside. I sent an e-mail to Lexus and they stated they were there for looks only.
Aloha,
Larry
Oh nice, I didn't even notice, that's a brilliant idea. Thank you!
Old 10-08-14, 12:34 PM
gman1337
gman1337's Avatar
It would be nice to have a aftermarket intake, but its not worth the risk..
Old 10-08-14, 01:08 PM
simon3huna
simon3huna's Avatar
Default risk
hmm. and what big risk is that? if it good quality brand nothing can possibly go wrong with it.
Old 10-08-14, 04:51 PM
Hermes
Hermes's Avatar
You're only risk of having a CAI is if you hit a puddle and your intake takes in water, or if you live somewhere where it gets extremely cold and you're driving around for a while, and if you park you car (if it's humid) an ice block will form over your intake.
Personally I wouldn't worry about any warranty issues because there are rarely any, and if something does occur, just swap it back to your OEM intake, and take the car in.
If you have a SRI, you have nothing to worry about.
Old 10-10-14, 04:34 PM
vbx
vbx's Avatar
Originally Posted by Hermes
Most CAI I have seen were at the bottom of the bumper near the wheel well, or behind the bumped near the bottom, not just behind the bumper...
Which has better flow and not risk sucking up water? Front grill or bottom wheel wells?
Both cold air none the less. One is less of a hassle. The other ends up having a bunch of sand and debris cause it sits so low.
Old 10-11-14, 08:26 AM
Hermes
Hermes's Avatar
I've never heard of anyone having issues with sucking up sand and debris, and if there was a possibility of that, a $15-$20 cover would guard would fix this problem.
Old 10-12-14, 07:08 PM
sucks2bu
sucks2bu's Avatar
Specifically, putting any aftermarket part on your vehicle can not void your warranty per the Magnuson Moss Warranty Act. In this WikiPedia article, see the requirements:
"Warrantors cannot require that only branded parts be used with the product in order to retain the warranty.[7] This is commonly referred to as the "tie-in sales" provisions,[8] and is frequently mentioned in the context of third-party computer parts, such as memory and hard drives."
I know it says computer but it applies to all products.
This requirement forces the manufacturer or dealer to prove that it was the aftermarket part that caused the issue.
Below is a link:
http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
Old 10-13-14, 08:22 AM
Hermes
Hermes's Avatar
Below is a link:
This is specific to the United States
Old 10-13-14, 08:40 AM
dasbuch
dasbuch's Avatar
Below is a link:
The tie-in sales provisions have nothing to do with REMOVING a factory car part and replacing it with an aftermarket part and expecting the dealer to support your modifications. It is designed to prevent a situation like Intel selling you a chip, then specifying it must be used with an Intel brand motherboard, which must only use Intel brand hard drives.
It's to prevent you from being forced to spend more money on a single vendor's product while simultaneously removing your choice to evaluate another vendor's comparable product. In the case of purchasing a car new, you've already made the choice to buy the car as-is and agreed to any terms the manufacturer of the car as a whole has put forth by doing so.
In this case there is no tie-in sales issue and thus no removal of choice.
I've never heard of a court forcing a dealer to provide support for whatever custom modifications a buyer might have done on his own.
Even the same is true with computers. If you buy a computer with a Hitachi hard drive, then decide to replace it with a Seagate drive, if the hard drive fails and you try to send it all back to the vendor, they have the right to say "this is not the drive we sold you", they can tell you to put the original drive back in. If heat from the faulty drive damaged the motherboard, they do not have to eat the cost (although in the interest of customer support they might).
Old 10-13-14, 11:13 AM
sucks2bu
sucks2bu's Avatar
See below for the link to the FTC site and the answer from the FTC:
This should answer the question.
http://www.consumer.ftc.gov/articles...ne-maintenance
Will using 'aftermarket' or recycled parts void my warranty?
No. An 'aftermarket' part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. A 'recycled' part is a part that was made for and installed in a new vehicle by the manufacturer or the original equipment manufacturer, and later removed from the vehicle and made available for resale or reuse. Simply using an aftermarket or recycled part does not void your warranty. The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket or recycled part. Still, if it turns out that the aftermarket or recycled part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket or recycled part caused the need for repairs before denying warranty coverage.
Old 10-13-14, 11:45 AM
dasbuch
dasbuch's Avatar
Which is pretty much a no brainer for them to do with the onboard black boxes of modern vehicles, which can show them the exact timestamp that an aftermarket part replaced the factory part, the side effects of having done so, and the time that the car owner swapped back to the factory part before bringing it in for service, providing difficult to dispute evidence of warranty fraud by the customer.
The dealer has the right to say no, then it's up to you to pay a lawyer to take them to court. Then it just comes down to whether you have as much time and money to throw at the lawyers as their corporate legal department does. Let me know how that turns out.
The truth is that if the problem is not caused by the part they will probably know it right away and take care of it. It's when the aftermarket part does have some sort of negative effect on the vehicles reliability or performance that you're glued and screwed, and there's no way of knowing if it will until it's too late. Not worth the risk.
Old 10-15-14, 01:08 PM
gman1337
gman1337's Avatar
Took the words right out of my mouth.. its not worth the trouble. The dealer will find SOMETHING that relates the aftermarket part to the issue
Old 10-15-14, 03:47 PM
Hermes
Hermes's Avatar
CAI/exhaust don't require reprogramming, I don't see how the blackbox would record you swapping the parts out. The black box records speed before an accident, whether seat belts were worn, did air bags deploy, where the car was hit etc.
Old 10-15-14, 05:30 PM
dasbuch
dasbuch's Avatar
Car manufacturers have diagnostic readability of far more parameters than are used in crash forensics. A sudden change in one parameter, which suddenly changes back right before the car lands at the dealership could easily be detected. The diagnostics in many cars are such that they can tell you the exact time in and out of a passenger in the car, it has nothing to do with the electronics of the part itself. Even something as seemingly low tech as a tire change can often be detected.
Old 10-15-14, 10:29 PM
Hermes
Hermes's Avatar
In most manuals these days you'll find something that says:
“This is your car and the data belongs to you. Unless the cops ask for it. Or in case you decide to sue us.” regarding the EDR/Black boxes.
EDRs and the data they store belong to vehicle owners. Police, insurers, researchers, automakers and others may gain access to the data with owner consent. Without consent, access may be obtained through a court order. For example, in a Florida criminal case involving a vehicular manslaughter charge, the police obtained a warrant to access the EDR data.
For crashes that don't involve litigation, especially when police or insurers are interested in assessing fault, insurers may be able to access the EDRs in their policyholders' vehicles based on provisions in the insurance contract requiring policyholders to cooperate with the insurer. However, some states prohibit insurance contracts from requiring policyholders to consent to access.
We own the data, and a dealership may not legally access that data without our permission, or a court order, which I highly doubt they would do. Should they access the data without our consent or a court order, there would be legal repercussions.
So weather you swap out after market parts or not, the dealership would have no idea.
Quick Reply: does aftermarket cold air intake void any warranty?
