Will they fit?
Will they fit?
Hello boys and girls. Do you think these will fit okay on my 14' IS350 Fsport? I'm looking at a staggered fitment.
Rim Diameter 20 inches
Rim Width 10.5 inches
Bolt Pattern (Number of Holes) 5
Bolt Pattern (Pitch Circle Diameter) 114.3 millimeters
Offset 28 millimeters
Backspace 6.75 inches
I can tell you now that a 20x10.5 et28 will definitely not work unless you plan on doing some major modifications to your quarter panels. I'm running 20x10.5 et45 and the wheel already sticks out past the rear quarters. The wheel spec you just posted would stick out 17mm more.
Good stuff guys. Thank you..
I'd like to go with Nitto 555 tires and he is saying 275/30's on the rear and 235/35's on the front do you think that is fine? I told him your set up sternb818 and he said it will look exactly like yours which is what I want. I DO NOT want my wheels sticking out at all.
hovik92 He says they are larger then 60.1mm says most aftermarket rims are? and he would include a set of adapters for me.
LexusRules
Wheels, Tires & Brakes Forum
11-26-01 04:36 PM
