Passenger armrest DIY
Old 08-31-14, 08:29 AM
STPMini
STPMini's Avatar
Default Passenger armrest DIY
My wife complained of the lack of a proper armrest on the console for the passenger. So I put together a little armrest pad to fix the issue. And when not in use it fits nicely in the glovebox.
Old 08-31-14, 09:26 AM
SCSurf
SCSurf's Avatar
Cool! DIY materials and steps?
Old 08-31-14, 09:38 AM
STPMini
STPMini's Avatar
I used a piece of 3/16" peg board that I cut to shape with a jigsaw. A couple layers of the foam that I had laying around that goes under laminate flooring. I used this because I wanted to keep the entire thing fairly thin while still providing a little bit of padding. And finally the outside material actually came off my MINI Cooper when I replaced the armrest covers with leather. This material is a synthetic material, however it matches pretty good to the interior of the IS.
I then stapled the outside material to the peg board and hot glued a piece of felt on the bottom to keep the staples from scratching anything. And then grabbed a few pieces of closed-cell foam I had laying around to keep the whole thing from sliding around.
Old 08-31-14, 02:46 PM
nayuta
nayuta's Avatar
that's brilliant!
Old 08-31-14, 03:22 PM
Trish67
Trish67's Avatar
Fantastic! You should manufacture these and sell them.
Old 08-31-14, 07:19 PM
eyeball
eyeball's Avatar
Patent this before it's too late!
Old 09-01-14, 12:28 AM
FinaLpeace
FinaLpeace's Avatar
The image just shows us an even better picture of how the center console could have been position way much better. Now it looks more finish and luxurious without having to see two cup holders cutting off the arm rest.
Old 09-01-14, 05:54 AM
STPMini
STPMini's Avatar
I did notice though that the surface there is not flat and I am going to need to make some modifications to the design to mitigate this issue.
Thanks for the compliments.
Old 09-01-14, 10:36 AM
goshawk823
goshawk823's Avatar
awesome work. my wife complained of the same thing. I was going to trace the circles of the cup holder as a template and build something similar, but had no idea what I could use to cover it.
Old 09-02-14, 11:57 AM
llcw79
llcw79's Avatar
Amazing work! My wife complained too but I just ignored....
Old 09-02-14, 01:14 PM
STPMini
STPMini's Avatar
Tried that, didn't work out so good.
Old 09-02-14, 01:15 PM
STPMini
STPMini's Avatar
I don't really like how the bottom turned out and will probably revisit that with a more robust design. Maybe this weekend.
Old 09-02-14, 04:03 PM
cFoo
cFoo's Avatar
This is awesome. It'll stop the *****ing about how useless the cup-holders are too!
Old 09-03-14, 10:34 AM
NickD82
NickD82's Avatar
Use plastic cups that fit perfectly into the cupholders to gauge what size / mould you can make.
Old 09-03-14, 11:14 AM
STPMini
STPMini's Avatar
Great idea. I will give that a try.
Quick Reply: Passenger armrest DIY
