Hardwiring a radar detector
Old 08-31-14, 07:06 AM
mark1281
mark1281's Avatar
Default Hardwiring a radar detector
I've been searching on the forum and haven't found anything conclusive. I pulled down the overhead console and there are two harnesses but nothing like this link https://www.clublexus.com/forums/is-...ew-mirror.html. I was wondering if you guys could help me out. Thanks.
Old 08-31-14, 09:56 AM
4TehNguyen
4TehNguyen's Avatar
i hardwired mine into an ignition fuse near the pedals.
Old 08-31-14, 12:05 PM
mello03
mello03's Avatar
I wired mine into the fuse box under the steering column. I can't remember which fuse, just a powered acc fuse. No issues.
Old 08-31-14, 12:26 PM
mark1281
mark1281's Avatar
Hmm. There has got to be a way to do this in the overhead console. Thanks for the input guys
Old 08-31-14, 02:12 PM
4TehNguyen
4TehNguyen's Avatar
im sure there is, but dont know the wiring diagram to know what colors you need to tap into. My detector is mounted just above the center speaker grille, and the escort smart code silence button is mounted behind my wiper stalk, all wires are hidden
Old 09-01-14, 11:21 AM
mark1281
mark1281's Avatar
That makes sense. I'm hoping that someone has or can find the diagram. I have my V1 on a visor clip on the visor. That is why I want to use the overhead console.
Old 09-01-14, 12:38 PM
dojoman
dojoman's Avatar
Get a mirrortap from link below then tap blue wire (ignition power) and purple (ground) it's right from blue wire.
http://www.mirrortap.com/mt2000.html#Micro
Pin 1 (Blue): Ignition Power
Pin 2 (Puple): Ground
Pin 3 (not on ewd?)
Pin 4 (Green): Signal for light control
Pin 5 (White): Signal for light control (both are MPX)
Pin 6 (Pink): Power
Pin 1 is fused with the 10A IG1 NO.3 fuse
Pin 6 is fused with the 10A MPX-B NO.1 fuse
Old 09-01-14, 01:59 PM
mark1281
mark1281's Avatar
Pin 3 (not on ewd?)
Pin 6 (Pink): Power
Did you do this with your IS? I looked at the back of the rear view mirror and there isn't a harness there.
Old 09-01-14, 02:07 PM
dojoman
dojoman's Avatar
Yes. Your car doesn't have auto dim mirror? Did you pull down the plastic cover to find the connector?
Old 09-01-14, 02:11 PM
mark1281
mark1281's Avatar
Yes it does. The plastic cover on the mirror housing? Because I've dropped the overhead console and no such luck. Thanks for your help.
Old 09-01-14, 03:49 PM
dojoman
dojoman's Avatar
There's a cover in front of mirror on the glass. It looks like this. Remove the cover by sliding down on the cover, you can see the wire harness slightly. You can then pull off the cover after sliding down this cover. Ignore the other wire on the outside. It's my dash cam wire.
Old 09-01-14, 04:17 PM
mark1281
mark1281's Avatar
Thanks man. I used my old wire tap from my G and tapped it in. Works like a champ. Thanks again for the help
Old 09-01-14, 04:30 PM
mmarshall's Avatar
Since you're right next-door in NC, I thought I'd pass along the tip that the use of a detector is illegal in adjacent VA....though you may have one in your car if it is turned off. The state troopers have detector-detectors.....and can tell when you are using one. If so, they have the right to stop and search....confirmed by the courts. Penalties include a fine and/or impoundment of the device. No warnings. No excuses.
Old 09-01-14, 04:32 PM
mark1281
mark1281's Avatar
Since you're right next-door in NC, I thought I'd pass along the tip that the use of a detector is illegal in adjacent VA....though you may have one in your car if it is turned off. The state troopers have detector-detectors.....and can tell when you are are using one. If so, they have the right to stop and search....confirmed by the courts. Penalties include a fine and/or impoundment of the device. No warnings. No excuses.
That's why I love living in Texas
Old 09-01-14, 04:34 PM
mmarshall's Avatar
Texas, though, even with higher speed limits, has a reputation for some pretty tough cops.
Quick Reply: Hardwiring a radar detector
