Opinions Please. . .
Old 08-31-14, 06:56 AM
egmmbah
egmmbah's Avatar
Default Opinions Please. . .
I have a 2014 IS250 F-Sport, Incurve IC-S10 20" wheels 20x9 front 20x10.5 rear, rear offset is +45. Rear tires are 275/30/20, debating between RS*R down, and Tien S-Tech springs, don't want to rub in the rear, opinions???
Old 08-31-14, 04:20 PM
egmmbah
egmmbah's Avatar
127 views and no response :-/
Old 08-31-14, 04:46 PM
xxwhosnxt
xxwhosnxt's Avatar
I'm on 20's with rsr downs no rubbing at all but my rear tires are 255/30
Old 08-31-14, 06:16 PM
Mr_VFS1
Mr_VFS1's Avatar
I am running 20x9/20x10.5 Vossen CV5 front offset is 38 rear is 45 225/30/20 front tire and 255/30/20 rear tire with rsr down springs and no rubbing issues. I am actually going to get 235/30/20 in the front when I go for new tires.
Old 09-01-14, 06:32 AM
egmmbah
egmmbah's Avatar
Thank you, my tires are already mounted I didn't want sooo much of a stretched look so I went with the 275's, I have a feeling its going to rub bad
Old 09-01-14, 08:05 AM
Mr_VFS1
Mr_VFS1's Avatar
I have a one finger gap with my 255's in the rear so 275 is going to be really bad. You may have to get new tires that are smaller or roll your fenders.
Old 09-02-14, 04:11 AM
Stitch626
Stitch626's Avatar
same here but 275 will rub!
Old 09-04-14, 07:05 AM
egmmbah
egmmbah's Avatar
So crazy, so nobody at all on here is running 275's? My 275's are a bit stretched now I couldnt imagine a 255
Old 09-04-14, 07:12 AM
IS350S2K
IS350S2K's Avatar
I run 265/30 on 19x10.5 et45 and can tell it rubs a little during hard corners.
Old 09-04-14, 07:18 AM
NVMarkus
NVMarkus's Avatar
I'm on 275s on 19 inch wheels with a 38 offset, I am not lowered at all and when i first got the tires they rubbed a little over some bumps.... with stiffer spring rate I don't think that I would have rubbed at all...
the 275s cover the edge of my wheels better, I am also in an AWD so I had to match size with the front...
Old 09-04-14, 10:55 AM
juvi22003
juvi22003's Avatar
275 is a lil too wide, a 255 or 265 would be perfect
Old 09-04-14, 01:25 PM
egmmbah
egmmbah's Avatar
@IS350S2K what suspension do you have?
Old 09-04-14, 01:58 PM
timmy0tool
Forum Moderator
timmy0tool's Avatar
what tire brand? not all tire sizing is equal. for example a 275 toyo may run a smaller sidewall than a 275 nitto.
the best way to determine is to "simulate" the car being lowered, either by jacking the wheel upwards toward the fender, or get your heavy-set friends to help in the back seat .
Old 09-04-14, 03:28 PM
Stitch626
Stitch626's Avatar
Originally Posted by Diego@Vossen
Like everyone else said 275/30 will be too aggressive for the rear. I personally wouldn't go more than 265 max! 255/30/20 has been the more popular tire size with our own 20x10.5 +45 and 20x10 +45 and sits perfect with RS*R Down Springs.
Agreed I ran a 265/30/20 on my very first set of Work Wheels and it rubbed and I been running 255/30/20 on my last 2 Vossen wheels with no rub
Old 09-04-14, 03:30 PM
1sWt2GS
1sWt2GS's Avatar
its definitely gonna rub.
Quick Reply: Opinions Please. . .
