New wheels - "Check AWD System" alert
Old 08-27-14, 02:01 AM
  #31
jbkhat303
jbkhat303's Avatar
Forum429 what are you talking about? Why would you compare a front 20 inch wheel to an 18 in rear wheel? Changing to the 35 aspect ratio will most likely fix the problem.
Old 08-27-14, 05:15 PM
  #32
DoomBuggy
DoomBuggy's Avatar
Originally Posted by Kuz
Ordering the 225-35's today. Thanks for your insight everyone!
Kuz, did you purchase yet?
Are any other members running 35 series tires on a 20" wheel? I wanna see how it looks up front. How much, if any, would this restrict ride height? I planned on dropping my front end significantly to sit on top of the 30 series tires. Hoping the taller sidewall doesnt affect anything TOO much.
Old 08-27-14, 08:58 PM
  #33
forum429
forum429's Avatar
Why would it matter if it's front or rear, 20 or 18"?
Its still need the same overall diameter of 25 inch regardless to have the correct reading.
If using both rear wheels would be easier for you people to understand then sure I will post it.
255/35R18 overall diameter 25.03"
255/30R20 overall diameter is 26.02
Still 1" bigger and 3.98% difference.
Similar size difference if I use 225/40R18 front wheel for comparing.
Do the f-ing math.
Old 08-27-14, 09:26 PM
  #34
larry13
larry13's Avatar
Originally Posted by forum429
Why would it matter if it's front or rear, 20 or 18"? Its still need the same overall diameter of 25 inch regardless to have the correct reading. If using both rear wheels would be easier for you people to understand then sure I will post it. 255/35R18 overall diameter 25.03" 255/30R20 overall diameter is 26.02 Still 1" bigger and 3.98% difference. Similar size difference if I use 225/40R18 front wheel for comparing. Do the f-ing math.
lmao thank you
Old 09-03-14, 09:57 AM
  #35
Kuz
Kuz's Avatar
They are arriving today and going on tomorrow for a test.
Old 09-03-14, 05:22 PM
  #36
DoomBuggy
DoomBuggy's Avatar
Cant wait to see photos! I just got my refund back from TireRack for the incorrect set.
Old 09-04-14, 09:43 PM
  #37
jbkhat303
jbkhat303's Avatar
The op has 20 inch wheels front and back. No one is telling him to use 35 ar on his 18 inch Front wheels. We're saying to use a 35ar on his 20 in wheel. Having the overall 26in diameter will only affect his mph reading, which will be off, but it will not give him the error that he's getting.
Switching to the 35ar front tire will give him overall diameter of 26.2 front and 26.02 rear. Well within tolerance to prevent the message he's getting.
Do the f-ing math.
Old 09-04-14, 10:33 PM
  #38
forum429
forum429's Avatar
Lets put it in a simple conclusion.
Do you think 225/45R18F 255/40R18 is a correct size for the car?
Old 09-05-14, 07:39 AM
  #39
Kuz
Kuz's Avatar
225-35-20 FIXED THE PROBLEM.
Anyone running 20x9F 20x10R wheels on an AWD 3IS, 225-35-20F and 255-30-20 is the correct size.
Old 09-05-14, 07:40 AM
  #40
Kuz
Kuz's Avatar
Thanks for all of your input, especially those suggesting the proper solution!
Old 09-05-14, 07:46 AM
  #41
Kuz
Kuz's Avatar
Sorry for the crude photos. I'm at work and the forecast looks shi!!y. So she's a little dirty, but you get the idea.
Attached Thumbnails New wheels - "Check AWD System" alert-photo-1.jpg   New wheels - "Check AWD System" alert-photo-2.jpg
Old 09-05-14, 10:50 AM
  #42
DoomBuggy
DoomBuggy's Avatar
Nice man!
Thanks for being the guinea pig for us AWD guys! Im happy to hear that fixed the problem.
Old 09-05-14, 07:11 PM
  #43
jbkhat303
jbkhat303's Avatar
Glad that worked for your kuz. The wheels look great
Old 09-06-14, 11:33 AM
  #44
Kuz
Kuz's Avatar
Thanks fellas!
Old 09-06-14, 03:11 PM
  #45
mrkjsn
mrkjsn's Avatar
Glad it worked out. Car looks fantastic!
Quick Reply: New wheels - "Check AWD System" alert
