New wheels - "Check AWD System" alert
Old 08-25-14, 08:04 PM
mrkjsn
mrkjsn's Avatar
Originally Posted by forum429
You are running wrong size of tires.
You need to keep the front and rear at the same or very close overall diameter.
To keep your speedo and odometer correct you need:
F225/30R20
R255/25/20
Where would you even find 255/25-20? I don't think anyone makes them.
Old 08-25-14, 10:45 PM
forum429
forum429's Avatar
No one makes this size.
But that's the correct size by calculation.
Anything that's diameter is 25" is the correct size.
Old 08-26-14, 05:25 AM
mrkjsn
mrkjsn's Avatar
Sorry, but no, the correct solution has been already suggested. Change the fronts to 225/35.
Old 08-26-14, 06:22 AM
Kuz
Kuz's Avatar
Ordering the 225-35's today. Thanks for your insight everyone!
Old 08-26-14, 06:27 AM
larry13
larry13's Avatar
wouldnt 235/30 also work?
Old 08-26-14, 10:15 AM
Kuz
Kuz's Avatar
Pretty sure this is useful info... the wheels are 20x9F and 20x10R.
Still recommend 225-35? With 255-30 on the rear?
Thanks for all of you guidance!
Old 08-26-14, 10:16 AM
larry13
larry13's Avatar
Originally Posted by Kuz
Pretty sure this is useful info... the wheels are 20x9F and 20x10R. Still recommend 225-35? With 255-30 on the rear? Thanks for all of you guidance!
you could probably run 235 or even 245
Old 08-26-14, 10:23 AM
Kuz
Kuz's Avatar
I know I "could". But I want to be precise, so that the alert doesn't come up anymore.
Old 08-26-14, 10:25 AM
larry13
larry13's Avatar
are you sure your sensors are installed right?
Old 08-26-14, 10:48 AM
Kuz
Kuz's Avatar
Yes. They are reading the PSI just fine. It's the "Check AWD" Alert that bothers me.
Old 08-26-14, 10:49 AM
larry13
larry13's Avatar
sent you a pm
Old 08-26-14, 11:05 AM
Kuz
Kuz's Avatar
Originally Posted by zarraz
I have an awd with 225/35/20 front and 255/30/20 rear with no warning, but my tire diameter is very close front to rear
What size with wheels do you have on there? I'm wondering if stretching would have an effect.
I'm running 9/10.
Old 08-26-14, 11:06 AM
larry13
larry13's Avatar
What size with wheels do you have on there? I'm wondering if stretching would have an effect. I'm running 9/10.
yes streching would. do you have discount tire or another national company by you?
Old 08-26-14, 05:09 PM
DoomBuggy
DoomBuggy's Avatar
Would love anyone's insight for my situation as well. The Niche wheels I'm eyeing are 8.5" front, 10" rear. I imagine I'd be fine with 225/35/20 F, 255/30/20 R? If not, or if there is a better combination, i'm all ears! My main concern with width is fender rubbing, as I'll be lowering quite a lot on coilovers.
Old 08-27-14, 01:37 AM
forum429
forum429's Avatar
No that's not the correct size.
OEM 225/40R18 is overall diameter is 25.09 in
225/35R20 is 26.2".
The new size is 1" bigger and 4.44% difference.
Anything over 3% is consider wrong size.
The speedo and odo is reading wrong.
Here is a very helpful link.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Of course if you just want something to roll around with then anything the same overall diameter would work.
But no 225/35R20 is not the correct size.
Quick Reply: New wheels - "Check AWD System" alert
