How to reset oil service light?
Old 08-03-14, 12:44 AM
xthizzlex
xthizzlex's Avatar
Default How to reset oil service light?
Just did an oil change on my 3is fsport and cant seem to figure how to set the oil light. Ive try reseting the 2is way but didn't seem to work. Any help would be great thanks CL.
Old 08-03-14, 08:33 AM
dojoman
dojoman's Avatar
Reset maintenance light is located in the gauge cluster setting not in the navigation screen setting.
Old 08-03-14, 08:50 AM
AMNss
AMNss's Avatar
Do the following :
Start your engine , then :
Break peddle 4 times with lights off
Lights on
Lights off
Lights on
Old 08-04-14, 12:01 AM
xthizzlex
xthizzlex's Avatar
How do I do it?
Old 08-04-14, 08:42 AM
dojoman
dojoman's Avatar
Originally Posted by xthizzlex
How do I do it?
Page 391.
http://drivers.lexus.com/t3Portal/do.../sec_07-02.pdf
Old 09-26-14, 07:41 AM
wjlandryjr
wjlandryjr's Avatar
If you did get an oil change, you just need to complete the initialization.
1. Turn on your car
2. Using your Steering wheel only, move the MAIN METER over to the right side. (the multi-info display)
3. You'll see the triangle with the exclaimation point, but instead scroll to the right to the "gear" symbol. (Settings)
4. From there on, pretty much self explained, "Start Initialization" "Yes".
5. Enjoy! No more pesky annoying light!
Old 09-26-14, 04:25 PM
mnm27mnm
mnm27mnm's Avatar
Originally Posted by AMNss
Do the following :
Lights on
Lights off
Lights on
Are you messing with him or this really another way to do it besides the setting menu in the cluster.
Old 09-30-14, 07:16 AM
wjlandryjr
wjlandryjr's Avatar
Doesn't seem legit as he is the ONLY one that mentioned this. What I just explained is by far the safest and easiest way to do it. But if you want to take a risk and do it his way, go for it. But record it, i want to see what happens LOL!
/brings popcorn
Old 09-30-14, 07:51 AM
AMNss
AMNss's Avatar
/brings popcorn
It depends on the situation, as I get a notification saying injectors maintenance required an I use the aforementioned procedure. If the notification you received is coming from a reminder from the screen, then you can deactivated from the maintenace tap within the car menu.
Old 09-30-14, 07:55 AM
AMNss
AMNss's Avatar
It looks like if I'm missing with him , but I'm not. If he deactivated the notification but it still wouldn't go then the procedure I wrote will work, since it resets the car notification system. By the way I do the provided procedure every 10k .
nht48823
HS 250h Model (2010-2012)
01-14-15 04:44 PM
coolewong
SC- 1st Gen (1992-2000)
30
01-23-12 09:16 AM
sonphung
04-20-11 01:51 PM
cincin
01-02-10 04:05 AM
Pwyll
04-02-07 06:46 AM
Quick Reply: How to reset oil service light?
