Square Tire Setup - Anyone Try This?
Old 05-26-14, 08:35 PM
jennypenny
jennypenny's Avatar
try keeping stock rears. and swap fronts with Michelin PSS.
you'd see the huge change.
also, understeering is actually good for beginner to intermediate drivers as the car is easier to control.
Old 05-26-14, 08:43 PM
UncleSpud
UncleSpud's Avatar
Originally Posted by bhvrdr
Well in case anyone was wondering if the rear wheels and tires fit up front...they don't. The rims themselves will clear the control arm but the tire won't. You'd need a more aggressive offset/spacers of probably about 10mm to 20mm to clear the a arm.
Mike
255-35-18 won't fit up front without spacers? Damn, Lexus isn't making it easy to go to a square set up. So, is 245-40-18 as wide as you can go up front without spacers?
Old 05-27-14, 06:44 AM
bhvrdr
bhvrdr's Avatar
The stock wheels sit in quite a bit from the fenders. They arent using a very aggressive offset. You might have been able to fit a 245 on the rim. Might have still needed a 5mm spacer or so though.
Mike
Old 05-27-14, 09:59 AM
Vairox
Vairox's Avatar
Mike
This is the space inside the front tire, 245 would be a tight squeeze on stock wheel
Old 05-27-14, 10:41 AM
JustNoize
JustNoize's Avatar
Mike
True had a blow out on the front, didnt want to put the donut on the front, took the rear off and then went to put it on the front No Bueno
Old 05-27-14, 12:56 PM
jcheng
jcheng's Avatar
You're not suppose to put the spare on the drive wheels!
Old 05-27-14, 04:33 PM
Vairox
Vairox's Avatar
You want a spare in the back because if it blows it's much better being in the back than the front which can flip your car or cause you to swerve and kill yourself being in the front, I'd put it in the back and drive slow get the issue fixed ASAP
Old 05-30-14, 09:28 AM
Vairox
Vairox's Avatar
I currently have 18x9 running 245/40 on all corners.
It does give a more neutral feel during hard turning and allows you to give a wee bit more power into the turns as well.
Seems a pretty close fit, you don't have any rubbing issues? did you go with hubcentric wheels or use rings?
Old 05-30-14, 10:49 AM
jcheng
jcheng's Avatar
Nope no rubbing issues at all. Running hubcentric rings.
Old 05-30-14, 11:01 AM
Vairox
Vairox's Avatar
Thanks, can u post a pic when u get a chance? think I'm gonna go this route... can't find any wheels that will accept the stock tpms though
Old 05-30-14, 11:37 AM
jcheng
jcheng's Avatar
Sure thing.
Old 05-30-14, 12:35 PM
UncleSpud
UncleSpud's Avatar
Since the 245-40-18 tire is taller and narrower than stock rear tire (255-35-18), do you have any problems with the speedometer? I also imagine the ride is a bit softer as well. Is that the case?
Old 05-30-14, 12:36 PM
reyoasian
reyoasian's Avatar
i would run 255/35R18 on 18x9, although right now i'm running 225/40R18 on 18x8.75
Old 05-30-14, 12:50 PM
jcheng
jcheng's Avatar
The difference isn't that far off like 1-2mph so it's no biggie.
I'm not dropped so i opted for a slightly higher sidewall to fill in some gap. Running V12 which have soft sidewalls to begin with, they are soft but offer a cush ride and i like the meaty tire look as well.
Old 05-30-14, 12:52 PM
jcheng
jcheng's Avatar
Will 255 fit in the front with a +40 offset? thats cutting it real close! I'm sure someone has done it.
IMO, its too much tire for the front.
Quick Reply: Square Tire Setup - Anyone Try This?
