IPOD/bluetooth connection error
Old 05-09-14, 05:52 AM
IS3Fguy
IS3Fguy's Avatar
Question IPOD/bluetooth connection error
Does anybody else is having connection error when playing music from Iphone 4 using USB cable and Bluetooth connection? It does not happen all the time with me, but it happens in the middle of playing music.
Old 05-09-14, 08:47 AM
offroad200
offroad200's Avatar
If you're using the USB to mainly charge, I would suggest using the power port instead. Having an iPhone plugged into USB kinda puts it into iPod mode (for lack of a better way to explain it) and messes with the bluetooth.
Old 05-09-14, 08:52 AM
hovik92
hovik92's Avatar
+1, I'm experiencing the same issues so I just use the bluetooth for audio and power supply for charging
Old 05-09-14, 08:56 AM
IS3Fguy
IS3Fguy's Avatar
Can I use the USB ports to transfer / view images from my iPhone onto the Nav display?
Old 05-09-14, 09:32 AM
tsopranoMB
tsopranoMB's Avatar
yes its a common issue with the 2014 IS...
it has to do with apple's AIRPLAY system....the system gets confused...so my recommendation would be to disconnect the audio player through the bluetooth when it is connected through USB
Old 05-09-14, 09:35 AM
tsopranoMB
tsopranoMB's Avatar
no you cannot directly, you would need to put the photo on a USB flash drive...
http://drivers.lexus.com/t3Portal/do...U/pdf/02-3.pdf
start on page 69
FSportWaxy
RX - 4th Gen (2016-2022)
07-28-19 07:23 AM
bmexxxzee
NX - 1st Gen (2015-2021)
01-02-19 04:08 PM
donkiboy
12-28-18 07:44 AM
saz25
RX - 3rd Gen (2010-2015)
17
09-17-12 12:50 PM
stanatl
04-27-10 11:12 AM
Quick Reply: IPOD/bluetooth connection error
