Will those wheels fit? START HERE.
Old 05-08-14, 01:49 PM
Jaydemm
Jaydemm's Avatar
Default Will those wheels fit? START HERE.
Took the idea from the 2IS thread. Lets start one for our 3IS!
Originally Posted by javyLSU
Want to know if your wheels will fit? Will it rub? What's the best offset? What sizes and widths should I buy? Start here.
This thread is the result of merging over 100 threads on the same topic - will these wheels fit on my IS? Feel free to ask any questions you may have on whether your specific wheels will fit on the 2IS, but please search this thread first - as you can see, there's plenty of information here already.
Javier
I'll Start, my 3IS is currently on RS*R Super Down springs. I recently got 19x9.5+22 rims all around and am debating what type of tires to get. I've asked a few people and most told me to do 225/40/19. Any thoughts on what best tires i could put to fit? Thanks ahead of time!
Old 05-08-14, 04:00 PM
mrtriad
mrtriad's Avatar
Subscribing to the thread because I'm looking for a set up as well.
Old 05-09-14, 12:54 PM
carderoni
carderoni's Avatar
Great idea for a thread! Can we start by mentioning the stock offset?
Old 05-09-14, 01:09 PM
jhs82
jhs82's Avatar
Stock 18" staggered setup
Front: 18x8" offset 45 mm, tires: 225/40
Rear: 18x8.5" offset 50 mm, tires: 255/35
Old 05-09-14, 01:34 PM
carderoni
carderoni's Avatar
Sweet, thanks!
Old 05-09-14, 01:38 PM
aTeAse
aTeAse's Avatar
I'd suggest posting pics as well with specs to maximize the use of this thread.
Old 05-09-14, 04:42 PM
Vairox
Vairox's Avatar
Let's try 18x8 +38 with 245/40/18 all around
Old 05-09-14, 09:24 PM
Jaydemm
Jaydemm's Avatar
Was able to get the 19x9.5 +22 square to work with a little bit of fender modding
Old 09-13-14, 10:04 AM
Jaydemm
Jaydemm's Avatar
Old 09-14-14, 07:27 AM
criticalgt
criticalgt's Avatar
will I be able to fit 19x8.5 et22 in the front? I will be dropped about 1.5" eventually...
If not, what is the lowest offset I can run with 19x8.5 and 235/35/19 tires?
Old 09-14-14, 11:59 AM
Jaydemm
Jaydemm's Avatar
I was able to fit 19x9.5+22 and still be alble to tuck on air. So that should be no problem
Old 10-04-14, 08:07 AM
DoomBuggy
DoomBuggy's Avatar
Bumping this thread, rather than clogging the board with another "will this fit."
I'm still hunting around for the perfect setup for my AWD. I really wanted to have 30 series sidewalls on all corners, but ran into rolling diameter issues if the front and rear were staggered. So, after messing around with a tire size calculator, it seems like a square setup would still work with the AWD, correct? Something like 235/30/20 on 9" wheels. Slightly disappointed that i wouldnt have as wide a tire in the rear, but i really want to avoid a 35 series tire in the front on a 20" wheel.
Just wanted a second opinion from the board! Still educating myself on mathematical side of wheels and tires.
Old 10-04-14, 08:15 AM
Loe
Loe's Avatar
A nice calculator:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Also, can someone post stock bore size & bolt pattern as well?
Old 10-04-14, 10:11 AM
Mr_VFS1
Mr_VFS1's Avatar
Are you lowered? If so, springs or coils?
Old 10-04-14, 02:01 PM
DoomBuggy
DoomBuggy's Avatar
I'm on J5 coilovers. Would like to keep it pretty low, as long as the 235 tire in front can clear the fender.
Quick Reply: Will those wheels fit? START HERE.
