Will those wheels fit? START HERE.
Old 10-05-14, 10:10 AM
CJW
CJW's Avatar
Would an 18x9.5 et 30 fit with 265/35's? Stock height. I don't want to do any fender mods/rolling etc.
Originally Posted by Loe
A nice calculator:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Also, can someone post stock bore size & bolt pattern as well?
60.1 bore, 5x114.3 pattern.
Old 10-11-14, 10:47 PM
Fsport14
Fsport14's Avatar
Anyone know if 18x9.5 +10 might fit? Im dropped on rsr super downs... Thanks in advance
Old 10-14-14, 11:19 PM
Jaydemm
Jaydemm's Avatar
The rears should be no problem, but fronts you may have an issue. I had 19x9.5+22 all around on super downs and i was rubbing a little.
Old 10-15-14, 05:27 AM
Reeladdict
Reeladdict's Avatar
Do you have any pictures from directly behind? To see how much the wheel sticks out beyond the quarter panel?
Old 10-15-14, 03:44 PM
Fsport14
Fsport14's Avatar
What tire size were you running?
Old 03-30-15, 03:22 PM
Reeladdict
Reeladdict's Avatar
Is anyone running a 19x8.5 +22mm in the front on RSR downs?
Thanks!
Old 04-19-16, 04:50 PM
fueler
fueler's Avatar
is anybody running a 275/30/19 rear on a 9.5" wide wheel with +36 offset? According to a calculator it will stick out 26.7mm further than a stock wheel/tire.
Old 04-20-16, 07:19 AM
dnasians
dnasians's Avatar
Stock Wheel Specs
Front: 18x8+45
Rear: 18x8.5+50
Center Bore: 60.1mm
PCD: 5x114
The list below is a set of sizes that would be a safe / flush fit under a 3IS with RSR downs, no camber mods. I have test fit these on a 350 and they should be applicable to all 3IS. The ones I tried are all 19"s but I'm sure it would apply to 18"s too. Any wider/lower offsets may require fender mods or heavy camber.
Front
19x8+25
19x8.5+30
19x9+35
Rear
19x9.5+40
19x10+45
Tires were all 225/35/19(F) and 255/30/19(R)
Currently, I'm running Volk RE30s 19x9+35 (effective) fronts wrapped in Nitto Invo 225/30/19 and 19x10+45 rears wrapped in 255/30/19 on RSR downs w/ SPC rear camber arms. No rubbing
Old 11-16-17, 11:16 AM
Bluntdrums
Bluntdrums's Avatar
Whats a little fender modding? i have this exact set up right now.. Trying to make it work .. would alittle chamber work?
Old 11-16-17, 11:17 AM
Bluntdrums
Bluntdrums's Avatar
i'm running 245/35/19 on 19x9.5 +22 i have the latest is350 body..
Old 11-16-17, 12:41 PM
SikhSipahi
SikhSipahi's Avatar
Was able to get the 19x9.5 +22 square to work with a little bit of fender modding
Very unsafe with that tire setup. Realistically that setup would not work with proper tires.
@Fsport14 that will not fit. Even you mount them on, you are looking at some insane poke.
Here are some tire suggestions for everyone:
8.0 wheel, Lowest 225. Best non stretch fitment 235
8.5 Wheel, Lowest 235. Best non stretch fitment 245 or 255
9.0 Wheel, Lowest 245. Best non stretch fitment 255
9.5 Wheel, Lowest 255. Best non stretch fitment 265
10.0 Wheel, Lowest 265. Best non stretch fitment 275
Old 11-16-17, 12:43 PM
Bluntdrums
Bluntdrums's Avatar
Whats Unsafe about it?? Whats proper tires? ...
Old 11-16-17, 12:58 PM
SikhSipahi
SikhSipahi's Avatar
His tires are very stretched, Similar to the image below. Look at my reply above
Attached Thumbnails Will those wheels fit? START HERE.-stretched_tire-560x418.png
Old 11-16-17, 01:11 PM
Bluntdrums
Bluntdrums's Avatar
im running 245/35/19 on 19x9.5 +22
Old 11-16-17, 01:15 PM
SikhSipahi
SikhSipahi's Avatar
Again it depends on the tires, some tires may not look as stretched. It's still better to run 255 or 265 on a 9.5 wheel. I believe your setup will rub (if not already), If you go with a wider tire.
Quick Reply: Will those wheels fit? START HERE.
