Momentary loss of acceleration
Twice now I've been driving and there was a few second lull where pressing the gas did nothing. The first time I was passing a car on the right, and the other I was pulling out between two cars to make a left on a busy road. Is there some kind of collision detection system that's causing the loss of acceleration? It's odd that the 2 times it happened I was so close to other vehicles. It's concerning since I needed to pull out quickly the second time and I was stuck for a few seconds without acceleration.
Anyone else experience this?
I'm not sure what reading the manual would've accomplished since my car isn't equipped with either feature.
No warning lights or buzzers went on either time, I just couldn't accelerate.
when you say it did nothing, do you mean literally no response, or the car just felt really slow and wasn't picking up? Sometimes it doesn't downshift as well as it should, you have to floor it all the way past the floor button. Another reason could be traction control but doesn't sound like the case.
Since both times were times when you would be using full acceleration inputs it could be traction control. Do you have and IS350? This would be more likely in that model. Do you notice the traction control light blink yellow at all when giving WOT during these times?
Mike
Mike
Literally no response from pressing the gas pedal. Honestly it felt like the car just died momentarily. The first one was a while ago so I may remember incorrectly, but I think it was hard to steer as well, as if the power steering stopped too. I remember thinking that the car just died and was pulling over when the gas pedal became responsive again.
I do have an AWD 350 but didn't notice any lights blinking and I didn't hit the gas exceptionally hard in either situation.
I've got a service on Monday, I'll bring it up at the dealership.
Well that definitely doesnt sound like traction control as an issue and you mentioning you have AWD makes it even less likely. Losing steering sounds like you lost all power to the vehicle/engine momentarily. This being an intermittent issue it can be a bear to hunt down. I would definitely bring it up to the dealer and hope the issue gets worse so they can find it and get it fixed. Good luck.
Mike
Mike
The pursuit of F
Ensure you can can reliably reproduce the hesitation with the technician in the car, otherwise it can be a lengthy frustrating process and failed expectations.
