Question on Driving Modes
Old 04-16-14, 07:11 AM
Moridan
Moridan's Avatar
Default Question on Driving Modes
Eco/Normal/Sport S/S+ Mode... the literature doesnt say much except it changes throttle response and power output. For the Sport modes it says that "The rear-wheel drive IS 350 F SPORT's Sport S+ mode also tightens the suspension..." Are the shocks somehow adjustable, or is this just marketing BS?
Old 04-16-14, 07:35 AM
JDR76
JDR76's Avatar
Received 1,627 Likes on 1,037 Posts
Yes, on the 350 F Sport models, the suspension is adjustable, known as AVS - Adjustable Variable Suspension.
Old 04-16-14, 07:38 AM
2GSKaizen
2GSKaizen's Avatar
Sport just adjusts the throttle mapping, and shift points slightly. Sport plus also tightens the steering feel, and adjust the damping of the shocks to a stiffer setting to tighten things up, and eliminate a little more body roll than usual.
Old 04-16-14, 07:40 AM
4TehNguyen
4TehNguyen's Avatar
Sport and Sport+ will hold the gears lower, which increases throttle response, but will reduce your mpg a little. Kinda wish I could have the stiffer suspension and steering but with normal mode throttle and transmission settings. You can kind of do that by doing Sport+ in Snow mode but the throttle feels so weak in snow mode.
Old 04-16-14, 07:52 AM
redcupr
redcupr's Avatar
The AWD IS350F-Sport also gets the adjustable suspension.
Old 04-16-14, 08:27 AM
AdvanSLF
AdvanSLF's Avatar
just hack that ***** lol
Old 04-16-14, 08:53 AM
dojoman
dojoman's Avatar
I wonder what it would be like to drive in Eco and Snow mode. haha
Old 04-16-14, 09:18 AM
yellow2112
yellow2112's Avatar
Pop your hood and look next to your strut towers and you'll see the little black box and wiring to each strut that controls electronic aspect of the suspension changes when you switch modes
Old 04-16-14, 09:29 AM
Moridan
Moridan's Avatar
Excellent, great to know! I have less than 300 miles on mine so far. But now I feel much better about the handling when I start pushing it.
Old 04-16-14, 10:26 AM
jay631987
jay631987's Avatar
How does the AVS work? I don't feel a difference between S and S+ mode in terms of suspension. I thought the AVS is only on the S+ mode? I guess it only stiffens up when it needs too? like on a straight smooth road it should be as loose as S mode?
Old 04-16-14, 11:10 AM
Vairox
Vairox's Avatar
Don't say that, the F-Sport folks get all pissy. That $4,000 had to go somewhere other than a grille.
Old 04-16-14, 11:22 AM
4TehNguyen
4TehNguyen's Avatar
go over a speed bump in both modes, you can definately tell the difference. If you open the hood you can see an actuator on each of the shock towers that changes the dampening rate between two different settings.
Old 04-16-14, 11:28 AM
dojoman
dojoman's Avatar
Nah we don't care much about AVS. I hardly notice it too, probably more noticeable on a track. $4000 goes to LFA gauge.
Old 04-16-14, 11:54 AM
jay631987
jay631987's Avatar
go over a speed bump in both modes, you can definately tell the difference..
I think that is where I cannot feel the difference. Maybe that is where AVS is doing its job? It's suppose to loosen up on bumps so it is comfortable and stiffen right back up for body roll etc.
Old 04-16-14, 12:01 PM
4TehNguyen
4TehNguyen's Avatar
no it changes over to a different damper setting so its stiffer at all times in that mode. Its not an active suspension, on something like the new Benz S550. Its an adaptive suspension meaning different modes. Active is when it is actively changing on its own based on road conditions.
Quick Reply: Question on Driving Modes
