Head Light Adjustment
Old 04-14-14, 02:54 PM
ArodIS250
ArodIS250's Avatar
Exclamation Head Light Adjustment
So after lowering my car on the RSR-super downs. My head lights are now pointing way to low! Anyone know how to adjust them? Maybe there's a DIY?
Old 04-14-14, 03:08 PM
TheShaddix
TheShaddix's Avatar
Park your car in front of a wall at night time, put some markings on the wall like tape and such where the light cutoff line is so you can have a point of reference as you adjust. Open the hood, you'll see the adjustment screws on each headlight that look like beer bottle caps. Use a flathead screwdriver to turn those. Not sure which way, but you can see the headlight cutoff line changing as you turn them. It's easier than it seems.
Old 04-14-14, 03:29 PM
sunnyx213
sunnyx213's Avatar
would you happen to have a picture by any chance? I see the bottle cap but can't reach it with a screw driver. One of my headlights is super low for some reason
Old 04-14-14, 03:35 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
There are some pictures and advice in this thread:
https://www.clublexus.com/forums/is-...headlight.html
Old 04-14-14, 07:04 PM
sunnyx213
sunnyx213's Avatar
I have been out in my garage for the past 40min to adjust the driver side headlight but I can't even move a notch! any other way to do it? damn this is frustrating
Old 04-14-14, 07:45 PM
Maxiii
Maxiii's Avatar
are you using a long phillips screw driver the one likes like a + ?
if you can't seem to turn it . try using a wrench and turn it. not sure what size,but from the pic the square looking on the bottle cap you can turn.
Old 04-14-14, 07:58 PM
sunnyx213
sunnyx213's Avatar
I used a flat head... I tried using the wrench but there isn't enough space to move around.. im going to give it a try again..thanks man!
Old 04-14-14, 08:01 PM
maddave
maddave's Avatar
don't use a flat head, use a very long philips screwdriver..
Old 04-14-14, 08:02 PM
Maxiii
Maxiii's Avatar
its easier to use a screwdriver with a + head.
yeah its sucks that there's not much room,but little by little turn with the wrench will work. it just takes time lol
Old 04-14-14, 08:11 PM
sunnyx213
sunnyx213's Avatar
lol, omg guy's. NOOB TO THE FULLEST. I think I made it to the wall of shame... I was trying to move it by inserting the flathead between the plastic screw...... not knowing that all I have to do was literally screw it... which only took me 3 min.... wow... so ashamed but thank you guys!
Old 04-14-14, 08:49 PM
Maxiii
Maxiii's Avatar
lol its all good. glad you solved your headlight problem lol
Old 04-14-14, 11:01 PM
TheShaddix
TheShaddix's Avatar
Don't feel bad, I tried to do the same! It's confusing at first.
Old 04-14-14, 11:35 PM
jennypenny
jennypenny's Avatar
so where exactly did you screw it the first time
and where was the actual location to screw it?
Old 04-15-14, 04:28 PM
sunnyx213
sunnyx213's Avatar
Do you see where I circled it? Just put the "+" screwdriver on top and start screwing. I believe clockwise raises it and counter clockwise lowers it.
Old 04-15-14, 07:15 PM
jennypenny
jennypenny's Avatar
awesome thanks!
Quick Reply: Head Light Adjustment
