Using same wheels for Summer & Winter Tires
Old 03-21-14, 02:06 PM
SonyHome
SonyHome's Avatar
Default Using same wheels for Summer & Winter Tires
I'm going to use the factory wheels for both Summer and Winter tires. I had my winter tires mounted in January and just today had my Summer tires put back on. I know with staggered setup you can't rotate the wheels but since I'm mounting tires twice year (until I burn through the factory summers and decide on summer wheels) will they be able to rotate my tires by mounting it on the opposite side each time?
Old 03-21-14, 02:56 PM
nitrox05
nitrox05's Avatar
The tire size are not the same so they will not be able to rotate front to back/back to front
Old 03-21-14, 02:58 PM
profet
profet's Avatar
OP understands that.
He's asking if it would be beneficial to rotate:
L <---> R
I think like 60% of turns are right hand turns. So yeah. You'll get some benefit out of it.
Old 03-21-14, 06:23 PM
J-Velocity
J-Velocity's Avatar
You can rotate side by side if they are asymmetrical tires
Old 03-21-14, 07:25 PM
Aeromotive
Aeromotive's Avatar
^^... and this depends on what tires you have. Best would be to either check the tire wall or ask your installator.
Old 03-22-14, 08:06 PM
SonyHome
SonyHome's Avatar
I'm using the factory tires for summer and Michelin X-Ice Xi3 for winter. From the pictures they look to be asymmetrical. Is that spec listed some where on TireRack.com?
Bridgestone Turanza ER33
http://www.tirerack.com/tires/tires....utoModClar=RWD
Michelin X-Ice Xi3
http://www.tirerack.com/tires/tires....omCompare1=yes
Old 03-22-14, 08:42 PM
Larry96815
Larry96815's Avatar
I run the same tires and wheels summer and winter.
Old 03-22-14, 08:46 PM
AdvanSLF
AdvanSLF's Avatar
If I remember correctly Sony, the factory summer tires are unidirectional (or directional) tires--meaning they are mounted on only one way. That being said you can't swing them side to side. If you get asymmetrical tires once you burn through the factory ones, only then can you rotate side to side
Old 03-22-14, 09:17 PM
J-Velocity
J-Velocity's Avatar
No you are wrong.
The factory ER33 are asymmetrical.
Old 03-22-14, 10:17 PM
SonyHome
SonyHome's Avatar
I agree these are unidirectional but what would be the issue for either of these sets of tires from rotating side to side? For sure X-Ice Xi3 look asymmetrical and ER33 have very slight difference from one side to next but not sure if that would cause issues if it's mounted on one side or the other. Does TireRack.com have specs indicating this?
Thank you.
Old 03-22-14, 11:18 PM
J-Velocity
J-Velocity's Avatar
What makes you think the Turanza ER33 are directional??
The Turanza ER33 molds a summer tread compound into a 5-rib, symmetric tread design that provides predictable handling and traction on dry roads, while circumferential tread grooves and lateral notches help evacuate water from under the tire's footprint to enhance wet traction and reduce hydroplaning.
The Xi 3 is actually directional.
Michelin's FleX-Ice silica-based winter tread rubber compound (offers firmness at higher temperatures for wet and dry road stability while it remains flexible at lower temperatures to enhance packed snow and ice traction) is molded into a directional tread design that helps evacuate water and slush to improve hydroplaning resistance
Newb2012
04-12-12 08:00 PM
EDouble79
Chicago Lexus Club
08-18-11 12:07 PM
jadeboy
12-31-07 09:08 AM
chadfetter
11-11-07 08:24 PM
pacent
Wheels and Tires Classifieds
10-17-03 08:27 PM
Quick Reply: Using same wheels for Summer & Winter Tires
