How to remove shift knob?
Old 03-16-14, 02:21 PM
dojoman
dojoman's Avatar
Exclamation How to remove shift ****?
I cannot unscrew the **** without having the whole shifter rotating. It's just screwed on according to picture but the whole thing rotates including the base pole. Am I supposed to rotate it when it's in D position only? On the 2IS I can unscrew the **** in Park position.
Old 03-16-14, 03:18 PM
iampraneel
iampraneel's Avatar
As you can see from the pic, the boot and shift **** are two pieces. You have to gently grab a hold of the ring at the top of the boot and pull down. It should snap out.
Old 03-16-14, 03:48 PM
dojoman
dojoman's Avatar
Got it thanks!!!
Old 06-19-19, 10:54 AM
bullit806
bullit806's Avatar
Is this instruction OK for 2016 ls 460?
Old 06-21-19, 06:52 PM
ex00
ex00's Avatar
Park it in the sun for a couple hours, heated plastic is easier to work it in my opinion. Just grab the base of the boot and pull it down.
Old 06-24-19, 09:13 AM
itsx
itsx's Avatar
Once you pop that boot down, you'll notice that the boot has a clip that won't work with most/ if any aftermarket shifters
To compensate for this, you can remove the clip entirely, which would involve you removing that part of the armrest.
The first 3 minutes of the Beat-sonic 2014-2018 Lexus IS F Sport iPhone Mirroring System Installation video does a really good job of illustrating the steps to take that console assembly out.
If you flip the shifter boot inside out, you'll see the plastic clip is just kinda tied down with a ziptie.
You can just cut the ziptie, and save the clip for when you decide to go back to stock.
My threaded shifter had an adapter and on the bottom of it had exposed threads.
I had boot back on the threaded "rod", threaded my shifter one, and fed it through the boot.
Once I had it where I wanted, I put a small ziptie on there to keep the boot on the new shifter, and put everything back together
XRM1996
GX - 1st Gen (2004-2009)
05-28-19 08:25 PM
zarraz
06-13-14 10:20 AM
GSTONY
11-15-13 04:41 PM
MrBruin09
09-30-13 01:38 AM
86'ed
06-09-10 11:48 AM
Quick Reply: How to remove shift knob?
