Question: 19 Inch Wheel Offset
It should, however, read this. https://www.clublexus.com/forums/sus...in-s-tech.html
I was surprised that his setup rubbed.
Are you going to lower your car?
Normally, I would say the 9.5+35 will fit, but in the thread link shown in my previous post, the OP rubbed after getting an alignment.
Atomic350 is running 9.5+38 with 265/30 Conti DWS tires and he isn't having any issues to the best of my knowledge.
I'm anxiously waiting on spotxc to install his super downs this weekend to see if his 19x10+38's rub. If he clears, then your 9.5+35's SHOULD clear since they are less aggressive by 3.5mm. Tire brand plays into it as well, some tires are narrower and have a more rounded profile than others which can make a difference.
jaznraz pretty much explained my situation.
TEIN S.Tech springs
I have 19x8.5 Front with 235/35-19.
I have 19x9.5 Rear with 265/30-19.
I choose 265 because nitto suggest that size is optimal for a 9.5 wide wheel.
I AM rubbing in rear, especially left. I think a 245/30-19 tire would clear, stretchy, but clear. I haven't had a chance to throw one on and test it. If it doesn't, I will probably put H.Techs in the rear and keep the S.Techs up front. It just gives me a headache thinking all the alignments... wheels and headlights.
TEIN S.Tech springs
I personally think that a 10" - 10.5 wheel width (19" wheel) is too much for this car.
You are limited by tire size and over the stock size on the f-sport rear (255/35-18) at best you adding an 1" of rubber - for what, all the grief.
A 265/30-19 WILL fit and be in spec on a 9" wheel in the rear. Any larger in tire or wheel width your asking for rubbing, and a smaller tire will be stretched on the larger width wheel.
Again, a 40-44 offset in the rear on a 9" - 9.5" wheel will fit 'nice'.
You can do a 8.5" up front with a 35 offset or an 8" with a 40 offset.
Use this link to play with various fits...
http://www.rimsntires.com/specspro.jsp
