tpms and aftermarket wheels.
Old 03-06-14, 09:13 AM
carderoni
carderoni's Avatar
Lots of good information in this thread. Where can I buy the Ateq Quickset?
Old 03-06-14, 09:59 AM
Renaeis250
Renaeis250's Avatar
i purchased a extra set of TPMS from Tire Rack , and have no problems.
Old 03-06-14, 01:11 PM
Vairox
Vairox's Avatar
Think Techstream can do TPMS and it's cheap
Old 03-06-14, 08:14 PM
afdavey
afdavey's Avatar
Originally Posted by 4TehNguyen
yea if you are in an area which you need a winter set of wheels, get another set of TPMS programmed for those and youll be able to swap wheels with minimal hassle between seasons. I though the car can recognize two sets of TPMS, so you dont you have to reprogram it each time?
Under the dash below the steering wheel is a button to switch between two 'programed' TPMS's - summer / winter. But they must be programmed to the vehicle first through the ECM.
Old 03-27-14, 03:01 AM
jhs82
jhs82's Avatar
What's the OEM number for the TPMS sensors?
Old 03-27-14, 09:29 AM
jhs82
jhs82's Avatar
Will these fit?
http://www.ebay.co.uk/itm/2311895705...84.m1423.l2649
Old 03-27-14, 09:55 AM
ISISGUY
ISISGUY's Avatar
Just make sure it's a good shop, I had new wheels and tires put on and kept the stock sensors and the shop inadvertently damaged one of the sensors. Took care of it, but still, it happens, the sensors are very sensitive and damage easily apparently.
Old 03-27-14, 10:49 AM
jhs82
jhs82's Avatar
The tire shop is not a problem. They're good.
But will the sensors i linked to fit my car?
Old 03-27-14, 04:54 PM
ISISGUY
ISISGUY's Avatar
The size is pretty standard so the fitment shouldn't be an issue. Shop just has to program them into your ecu to make them work.
Old 03-28-14, 03:09 AM
jhs82
jhs82's Avatar
But will the onboard computer be able to read the sensors? They all don't speak the same language, do they?
Old 03-28-14, 02:22 PM
ISISGUY
ISISGUY's Avatar
Each sensor has a serial number, that serial number needs to be programmed to the ecu so they can communicate. The only issue might be that some tire shops may only have software up to 2013 model year lexus but that's the only thing they have to do.
LxsCf RCF
RC - 1st Gen (2015-present)
05-14-16 12:15 PM
kevenhang
04-02-10 12:58 PM
wyee99
12-08-09 11:41 AM
Damaster32
07-18-08 05:08 AM
B.Diddy
12-28-07 07:52 PM
Quick Reply: tpms and aftermarket wheels.
