New Wheels, need spacers?
Old 01-23-14, 11:14 AM
Vairox
Vairox's Avatar
Default New Wheels, need spacers?
Current vehicle is 2014 IS350, I'm wanting to put on -
18" LEXUS ISF STYLE WHEELS
Make Alloy
Structure One Piece
Finish HYPER SILVER
Front Size 18X8
Offset +40
Rear Size 18X8
Offset ET +40
Bolt Pattern 5X114.3
Hub Bore 73.1
Plan to run 245/40/18 all around, obviously I'll need 73mm OD x 60.06mm ID hub centric rings, not sure if I'll need any spacers since the front and back are the same size? thanks.
Old 01-23-14, 03:53 PM
RastaRacer
RastaRacer's Avatar
Spacers would probably not be required but would make it look a lot better since the width is only a 8" and the offset is high like the oem wheels.
Old 01-23-14, 05:07 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
If you want to go conservative on the spacers, yet still get the a bit of a wider look and keep the OEM nuts and lugs, consider 5mm spacers. It's what I have, you can see my Build thread in my sig below.
Studiogeek
SC- 1st Gen (1992-2000)
37
05-30-13 08:08 PM
buckwhite
04-13-12 05:35 AM
STR
01-25-11 03:02 PM
SPEED&ECO.
05-13-07 12:01 PM
Sam Khoury
Wheels, Tires & Brakes Forum
10-17-02 05:45 AM
Quick Reply: New Wheels, need spacers?
