Will this specs be too agressive for my 3is?
Old 11-30-13, 11:56 AM
07awdis250
07awdis250's Avatar
Default Will this specs be too agressive for my 3is?
I will be lowering my car with the new Super Down springs from RS-R and, I also want to cahnge the wheels to varrstoen Es332 . I want to know if the specs posted below will be too agressibe for my car? which tire size will be good for this wheels?
19x9.5 +22mm
19x10.5 +22mm
http://www.ebay.com/itm/19-VARRSTOEN-ES332-5X114-3-WHEEL-FIT-LEXUS-GS300-GS430-SC430-TOYOTA-SUPRA-5X4-5-/130882511994?pt=Motors_Car_Truck_Wheels&hash=item1e7934a47a&vxp=mtr
Old 11-30-13, 09:45 PM
Timmah
Timmah's Avatar
I test fited my 19x9.5 +17 on rear and it will fit with some camber. anything more agressive would take a lot more work.
Old 11-30-13, 10:45 PM
07awdis250
07awdis250's Avatar
Thanks Timmah , What tire size do you have ? Did they stick out a lot? I think with 22mm I would need less work ?
Old 12-01-13, 06:08 PM
SonyHome
SonyHome's Avatar
Another member had 19x9.5 40mm offset in the rear and he experienced rubbing when he had full load.
https://www.clublexus.com/forums/is-...of-my-3is.html
I also saw others put 19x10 or 20" with no issues.
https://www.clublexus.com/forums/8258206-post838.html
Old 12-01-13, 11:09 PM
07awdis250
07awdis250's Avatar
Thanks for the links, from the info gathered I won't be able to run these wheels at all.
Old 12-02-13, 04:16 AM
Skinnyfats
Skinnyfats's Avatar
I would buy wheels and tires first before you put springs on your car. See how they fit few people are having rubbing issues riding on the stock suspension.
Old 12-02-13, 09:06 AM
07awdis250
07awdis250's Avatar
I'm going to lower the car and try the wheels to see how much they poke out . It's going to be aggressive but I think I can make them work .
Old 12-02-13, 10:09 AM
GSTONY
GSTONY's Avatar
It will fit with stretch tires
Old 12-02-13, 10:12 AM
OKSTANCE
OKSTANCE's Avatar
it will poke and look like poop with no camber and just a slight drop
Old 12-02-13, 11:45 AM
Timmah
Timmah's Avatar
245/45/19. that was on the back and it fit dectly. the 19x11 stuck out about 2 inches same offset. I just dont know how aggresive the Lexus camber can go.
Old 12-03-13, 11:54 AM
07awdis250
07awdis250's Avatar
you think it will fit by stretching ? I'm going to stretch the tires anyways because that how I had them on my 2is. My biggest concern is that I don't want it to be poking out to the point that it look like a frog
Old 12-03-13, 12:02 PM
OKSTANCE
OKSTANCE's Avatar
"I am running 19 x 9.5 (235/35/19) and 19 x 10.5 (265/30/19) wrapped on Nitto Invo"
quoted from
https://www.clublexus.com/forums/8249465-post33.html
10.5 is too wide for springs..unless u like that mexipoke
Old 12-03-13, 02:32 PM
07awdis250
07awdis250's Avatar
WOWW beautiful car man , what's the offset? what springs are you lowered on? If its not too much to ask can I have a pic from the rear to see how much they poke out ? thanks
quoted from
Old 12-03-13, 03:24 PM
Bass Mech
Bass Mech's Avatar
quoted from
this means nothing unless you post the offset.
Old 12-03-13, 03:31 PM
OKSTANCE
OKSTANCE's Avatar
https://www.clublexus.com/forums/sus...ml#post8249465
Quick Reply: Will this specs be too agressive for my 3is?
