IS 250F Subwoofer concern
Old 10-20-13, 02:46 PM
ibminh
ibminh's Avatar
Default IS 250F Subwoofer concern
Ok so I'm going to get the Lexus IS 250F sport but the only thing concern me is that it seems really hard to install after market part... Is it possible to install an amplifier and a subwoofer hook up to the stock head unit?
Old 10-20-13, 02:57 PM
John510
John510's Avatar
Search button. You will find my post of how to do this.
Old 10-20-13, 05:00 PM
ibminh
ibminh's Avatar
Thanks man. Just curious were you able to adjust the subwoofer from the stock headunit?
Old 10-20-13, 11:20 PM
John510
John510's Avatar
No. The JL amp has a remote bass boost **** I put next to the BSM switch. Its actually a really easy process.
Old 10-21-13, 09:50 AM
ibminh
ibminh's Avatar
Oh so the headunit doesn't have Bass options? I have my old Alpine amp which does not have remote bass control
Old 10-21-13, 12:27 PM
ddb
ddb's Avatar
Easiest way is to tap into the Bass signal that comes out of the stock Amp on the trunk. That is what I did on my old 2008 IS250.
I believe that the 3IS has the same setup as the 2IS. The stock Subwoofer should be a Dual Coil Subwoofer, so it has two sets of cables going to it (two Positive and two Negatives).
You have two options, you can eliminate the stock Subwoofer and use those lines to feed your aftermarket Amp (you will need an Amp that has Active Line IN to accept signals that are already amplified). This will allow you to completely control your Bass.
A second option is to tap on the signals and use it to feed your Amp while leaving the Stock Subwoofer still active (that is what I did on my setup). You loose a little bit of power on the stock Subwoofer but you really don't care as your aftermarket Subwoofer(s) will do the real job.
Your aftermarket Amp should be installed on the trunk, and you will need to run new power cables, one from the Battery Positive Terminal (place a fuse a few inches away from the Terminal) and another for the Ground (Negative) that can attach to the chassis on the trunk.
Finally, the Remote Switch to turn ON and OFF the aftermarket Amp will have to be either a manual setup (you will need to add a switch that you control) or find an aftermarket Automatic Switch that basically detects when there is a signal on the speakers (you would connect it to the Bass signal) and it will fire up the Amp whenever music is playing.
Reason to tap on the stock Amp and not on the Head Unit is simply because the signals between the two of them are digital not analog, so you would need a decoder, software... blah blah... and you would risk to damage your stock equipment.
To find out the correct wires for these projects, go to https://techinfo.toyota.com and create a subscription for 2 days, is only $15 and you will access all the diagrams for every single vehicle Toyota has, including Scion and Lexus. You will need to search for your specific vehicle and look for the wiring diagram for the Sound system. That is what I did and still do every time I get a new Lexus (I lease). I download any diagram I might need.
Good luck.
Old 10-21-13, 07:26 PM
ibminh
ibminh's Avatar
Good luck.
I didn't know the IS250 has a sub...Is it a standard for Lexus IS to have an external amp?
gflexus400
01-19-17 06:04 PM
drpatel77
06-01-10 10:53 PM
Baybarea
19
08-11-07 02:07 AM
nehal51086
09-19-06 06:02 AM
lexusnexus
IS - 1st Gen (2001-2005)
07-09-01 02:02 PM
Quick Reply: IS 250F Subwoofer concern
