How to: Changing Lane Change Flasher from 3 to 5 or 7
Old 10-09-13, 02:06 PM
vbx
vbx's Avatar
Originally Posted by bagwell
I only use this feature to change lanes and 3 is perfect for me (Audi)...5 would feel like I'm a senior citizen from FL.....I guess I change lanes faster than you guys
The purpose of the signal is to give other people a chance to know in advance that you are changing lanes. Which they can respond by letting you in, speed up or ignore you.
It's not about who can change lane faster or cuting people off in heavy traffic. Anyone can do that.
Old 10-10-13, 12:43 AM
jhs82
jhs82's Avatar
Originally Posted by vbx
WTH? I asked my sales rep to change mine to 5 but he says it's only available on the GS?
That's BS. I got mine done.
Old 10-10-13, 11:02 PM
Oxytocin
Oxytocin's Avatar
I did it myself, it's actually not that complicated once you read it and understand what it's asking you to do. I memorized the pattern, did a few dry runs in my head then did the actual programming in one go. It's like entering a cheat code for a game.
Old 10-10-13, 11:14 PM
yardie876
yardie876's Avatar
LOL cheat codes. Good times. I ended up doing it myself also after the dealer failed after 45 mins of trying.
Old 11-04-13, 03:43 PM
aTeAse
aTeAse's Avatar
What is this 3, 5, and 7 blinks you guys are talking bout
Old 11-04-13, 04:05 PM
yardie876
yardie876's Avatar
When you use the indicator to change lanes, if you click it half way, il blink 3 times and stop. There is a way to reprogram it to blink 5 or 7 times instead.
Old 11-04-13, 04:08 PM
jennypenny
jennypenny's Avatar
Originally Posted by Joeb427
3 blinks is the standard number. BMW and Benz goes with 3 blinks.
My son's Elantra has 3 blinks too.
yup.
i can concur that most cars are 3 blinks on half signal flicks
- audi
- bmw
- mercedes
- infiniti
---> lexus
Old 11-04-13, 04:22 PM
vbx
vbx's Avatar
I went to 2 different Lexus dealership in CA. Both said it couldn't be done. Should I bring in the pdf files as proof that it can be done?
Old 11-04-13, 04:39 PM
Kajn
Kajn's Avatar
Originally Posted by jennypenny
yup.
- audi
- bmw
- mercedes
- infiniti
---> lexus
My Benz 2012 GLK350 turning signal was 4 blinks (not 3) and I was very happy with the four blinks. I hate the 3 blinks on the GS.
Old 11-04-13, 05:05 PM
RaysurX
RaysurX's Avatar
Yup.. you should bring it with you. Though you might have better luck doing it yourself unless you are leaving the car for other service and you have the time to wait for them to read and figure it out.
Took me about 15 mins to understand the sequence and give it a try a couple of times.
I also went to a high volume Lexus dealer in So Cal (OC) and they didn't know what I was talking about when I asked.
Old 11-04-13, 05:07 PM
yardie876
yardie876's Avatar
Once I sat down and read the instructions after cursing to myself for 15 minutes trying to do it while reading, it literally took maybe 20 seconds. My dealership spent 45 mins trying to figure it out and gave up.
Old 11-04-13, 08:54 PM
albino1
albino1's Avatar
I had it done at Crown Lexus in SoCal.
Something weird I noticed though: my lane change sensors on my mirrors no longer function. I don't know if this is definitely related or not, but they used to work fine and now don't, and seemingly stopped around the same time I had the number of flashes changed. Anybody else have a similar problem?
Old 11-04-13, 09:20 PM
aTeAse
aTeAse's Avatar
Meaning; switching the signal marker up or down?
Old 11-04-13, 10:30 PM
RaysurX
RaysurX's Avatar
Your flasher stalk (rod / stick) actually has three positions 1) neutral - position while you are not touching it - 2) Right or Left - nudging it slightly up or down 3) Right TURN or LEFT TURN - flicking all the way up or down
Position 2 is what we are talking about, which is initiated by a gentle nudge. The flasher will (by default flash 3 times then automatically turn off). A lot of people (including me) feel that 5 is a good number to signal and transition into a lane.
If you are always flicking the flasher stalk entire up or down to position 3 then you would have not noticed position 2.
Old 11-04-13, 10:33 PM
dbs600
dbs600's Avatar
Any other settings we can customize!?
Any way of getting the entire manual from your shop?
Thanks!
Quick Reply: How to: Changing Lane Change Flasher from 3 to 5 or 7
