F sport lectronic cluster
Old 08-23-13, 08:57 AM
dasrakete
dasrakete's Avatar
Angry F sport lectronic cluster
Anyone out there know if you can switch between MPH and KM for your speedometer reading. I travel a lot in Canada and the speed is in kilometers per hour not miles per hour. Is there a facility in the driver information that can do this? Lexus has given me a "DUH" response.
Old 08-23-13, 09:20 AM
John510
John510's Avatar
Yes it's in the settings.
Old 08-23-13, 09:23 AM
dojoman
dojoman's Avatar
When F-sport gauge is in middle you can switch to different info like tire pressure, gear, ECO, ...the last item you can change from MPH to Kmph. Press right arrow to switch between the two.
Old 08-23-13, 09:37 AM
enoren
enoren's Avatar
You can change units using the Multi-Information Display -- the gauges, not the main screen. Scroll horizontally to Settings, press the center button to change settings, and scroll vertically to Units.
Old 08-23-13, 10:16 AM
dasrakete
dasrakete's Avatar
Thank you. I guess if all else fails ask those who know not those who should know. Glad this forum is available
Old 08-23-13, 10:26 AM
Evitzee
Evitzee's Avatar
Remember this: "The Owner's Manual is your Friend".
Old 08-23-13, 12:26 PM
Hoovey689
Hoovey689's Avatar
it's not always the most intuitive though. Some of the wording at times is downright
Old 08-23-13, 01:24 PM
RA040224
RA040224's Avatar
Where's the setting to view the tire pressure? Can't find it
Would have been nice to have had it when I had a nail in a tire.
Old 08-23-13, 02:02 PM
Hoovey689
Hoovey689's Avatar
under the 'i' information section towards the bottom of the scroll menu
Old 08-27-13, 10:09 AM
c3po33
c3po33's Avatar
How can I add this to my display #1 or #2. (sorry if I got the name wrong)
I can't seem to figure it out.
Old 08-27-13, 04:08 PM
RA040224
RA040224's Avatar
In the settings menu select driver info 1 or driver info 2. Each screen can display two pieces of information, top and bottom. Select the position where you want the info. You can now scroll down in the list of available information pieces. Select the one you want, then press back until you're out of the setting menu and move to the I display. Verify the new setting. In the 300h, when you scroll down in the I display, it shows Driver info 1, Driver info 2, Power distribution and blank.
Old 08-27-13, 08:10 PM
dojoman
dojoman's Avatar
If you're looking for tire pressure info you don't need to do anything. Just scroll down or up on "I" page. The last page is blank but this this where navigation turn by turn shows up if on a route.
histyle
GX - 2nd Gen (2010-2023)
04-06-21 02:21 PM
heidihidin
ES - 5th Gen (2007-2012)
04-01-19 07:09 PM
kadify
12-28-17 06:40 PM
Dahlyn
11-11-16 11:16 PM
Axvel
03-08-07 11:06 PM
Quick Reply: F sport lectronic cluster
