2014 IS350 RWD Non-F-Sport Front Brake Pad Dust Problem
Old 04-08-14, 07:52 AM
AdvanSLF
AdvanSLF's Avatar
1) if you're a weekend mountain/canyon runner, then stick with the f sport brake pads
2) if you're a daily driver with not much of #1, go for the regular IS350 front brake pads for your F Sport
3) if you're doing #2, the simplest fix is go to autozone, buy a pair of their pads (just as good quality), but here is the kicker--you will never have to buy pads again after your first autozone pair! that's right, next time you need to change pads, bring in your old worn autozone pads and they give you a new one. i have yet to do it on the IS as i'm still trying to figure out what pads work best for me/direction i should go for, but i got it for the camry family car and the pads are pretty good.
Old 04-08-14, 08:02 AM
4TehNguyen
4TehNguyen's Avatar
I had a set of OEM low dust front pads leftover from my 2IS that I swapped in. Not much dust. I swap in my dusty F Sport pads if I go to the track.
Old 04-08-14, 08:35 AM
FSPORTJC
FSPORTJC's Avatar
Old 04-08-14, 12:11 PM
link13
link13's Avatar
I am not a huge fan of Armor All products, but I use this stuff on my GS with very good results.
http://www.hardwareonlinestore.com/i...FbFFMgodI1QA3w
Old 04-08-14, 08:34 PM
gwud2go
gwud2go's Avatar
I've tried using that Armor All product a few times - doesn't seem to work as well as they advertise.
Is there a particular technique in applying it?
Old 07-18-14, 03:05 PM
rookie350
rookie350's Avatar
Left is the 04465-30500 right is the 30450; (went back and bought the other one after I was told they are the same)-clearly they are not. Haven't installed either but by the looks of the inside of the box alone I'm pretty confident 30500 is the high dust model. Just hope the 30450 works with my 06 is350; cause I remember for a while the low dust brake was only for the 350's and the 250's got their own low dust front pads later... if anyone can confirm this is the ISthree50 model before I put these on that'd be great.
Attached Thumbnails 2014 IS350 RWD Non-F-Sport Front Brake Pad Dust Problem-img_20140710_201331_648.jpg
Old 07-21-14, 07:25 PM
dizlex
dizlex's Avatar
Originally Posted by dojoman
I thought only F-sport brakes are high friction with lots of dust. Non-Fsport should be fine.
"Fine" is a matter of opinion. Even "normal" modern brakes can be quite dusty.
Lexus really should warn people about their cool "hi performance" (but does almost no one any real good) f-sport brakes.
Old 07-21-14, 07:39 PM
dseag2
dseag2's Avatar
Yes, those of us with GS F Sports feel your pain.
Old 07-22-14, 06:55 AM
JGard18
JGard18's Avatar
I had a friend who used to track his Miata often. He'd buy Autozone pads for his track weekend and once it was done and the pads were toast, he'd bring them back and get them replaced for free. However, after a few months and like a dozen pad exchanges, they told him to stop coming in.
Old 07-26-14, 01:27 AM
elbertc
elbertc's Avatar
My IS350 F Sport (3IS) brake pads were completely worn out at 10,000kms. That's quite short, especially when compared to my previous BMWs (which typically go up to 18,000kms for me). I'm now considering going for an after-market solution.
Anyway, with regards to brake dust, I agree that the amount of brake dust the IS produces is quite annoying. However, you can look at the bright side. Dust means that it's the pads that give way and helps preserve the rotors.
Old 07-26-14, 05:39 AM
4TehNguyen
4TehNguyen's Avatar
You are correct. I have both set of pads as pictured. I had a leftover set of new low dust pads I was going to use on my 2IS but I moved them over since F Sport brakes are so dusty. Black pads are F Sport and the light brown ones are low dust. I swap my front pads out for F Sport pads when I go to the track and swap them back for daily.
Old 07-27-14, 09:15 PM
dizlex
dizlex's Avatar
I don't know about that. On my BMW E46 I switched to aftermarket low-dust pads and they were also *much* easier on the disks. The stock pads/disks were quite dirty and did not last long.
Old 07-28-14, 06:07 AM
Antnie2418
Antnie2418's Avatar
I use C5 Gtechniq on my rims on my f sport and never had and issue I also have the coating on my entire car inside and out and works great and never experienced any type of issue with brake dust
Old 07-28-14, 09:30 AM
dAiLL3sT
dAiLL3sT's Avatar
I have a Ultra White F Sport and I've noticing alot of these random orange specs on the cars paint and also some pretty tough to remove black specs, is this due to the brake dust? Does anyone know how I can remove these specs safely?
Old 07-28-14, 09:37 AM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
Google "Industrial Fallout" and you will have your answer. You can also search for it on the detailing forum for ways to remove it from your paint.
Isboys306
03-13-19 09:06 PM
smokyis350
11-15-11 09:23 PM
IS350jet
12-19-06 04:17 PM
IluvIS350
11-04-05 05:23 PM
Quick Reply: 2014 IS350 RWD Non-F-Sport Front Brake Pad Dust Problem
