Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to Replace Footwell lights
Step by step instructions for do-it-yourself repairs
>>> LED & HID Lighting Upgrades >>> (with comparison photos)
#31
Here are some more comparison pics. These lights are a lot brighter than stock.Attachment 294448
Attachment 294449
Attachment 294450
Attachment 294451
The footwell is K-Spec 6 LED
The courtesy is K-Spec 9 LED.
I have yet to get pics of the reverse light and still need to install the passenger side. Am worried to install the trunk light since someone broke their's and I couldn't pry it open easily.
Will post more pics when I get them.
Attachment 294449
Attachment 294450
Attachment 294451
Great looking! These are must have and they are the most straightforward lights to change in the IS. Another thing to consider is the light under the side mirror. It also makes the same visual difference as the door courtesy light.
If Lexus has followed the same pattern as in 2IS, the reverse lights should not be difficult to change in the 3IS. You just need the right tool to unplug the plastic clips one by one to access the area. I have changed mine in 2IS and I find it useful for parking with a back wall. Literally you can see the two white spots on the wall. Of course, you don't need this aid when you have the back up camera.
#32
http://minkara.carview.co.jp/userid/...blog/30468429/
Here is the trunk light!
It is very tight and easy to break it(see photos in above link). That is why this Japanese LED seller provide the whole replacement trunk light set.
I did break mine and have to buy a new one (clear body only) from Sewell (usd14)
#33
#34
What tools does everyone use to remove the housings? I don't want to scratch anything and would like to find something that doesn't cost as much as the tools on Sewell.
#35
The closest side mirror should be the one from CT. There is a thread here that shows the step by step pictures. Do a search.
The first step for taking the mirror housing apart is tilt the mirrors all the way up to release the mirror piece from the housing. Just be careful because there is still some thin wires attached to the mirror piece, as well as some glue stuff.
#37
Those are bright. Thanks for the pics!
Attachment 294449
Attachment 294450
Attachment 294451
Attachment 294449
Attachment 294450
Attachment 294451
#38
#40
Instead of taking the chance of scratching or braking something with a screwdriver, I ordered a set of nylon prybar tools. I used similar to these when I worked as a mechanic some years ago, and they are great. Makes it impossible to scratch anything.
http://www.ebay.com/itm/9-PC-NYLON-PRY-BAR-SET-DASH-PANEL-TRIM-REMOVAL-TOOL-KIT-INSTALLER-MUST-HAVE-/271250428832?pt=Motors_Automotive_Tools&hash=item3f27c913a0&vxp=mtr
#41
Video Link: http://www.ebay.com/itm/9-PC-NYLON-PRY-BAR-SET-DASH-PANEL-TRIM-REMOVAL-TOOL-KIT-INSTALLER-MUST-HAVE-/271250428832?pt=Motors_Automotive_Tools&hash=item3f27c913a0&vxp=mtr
#42
#45
Most of the packages on the HID PowerHouse website have different type of LED's for the Dome and Map lights. Does anyone have any pictures or can someone tell me if when they are both on together if they look different or does it look good? Thanks.
