oem 2IS WHEELS ON 3IS 350
Old 07-17-13, 06:02 PM
Jlesz
Jlesz's Avatar
Default oem 2IS WHEELS ON 3IS 350
hey guys can anyone help me out i came across a good deal for some 2IS 250 AWD wheels for winter, does anyone know if they will fit on the 3IS 350 AWD
17"x8, 5x114.3, ET45, CB60.1
Old 07-17-13, 08:22 PM
AndyL
AndyL's Avatar
Hi Jlesz, I want to know as well.,,Same situation: having the 17" Lexus 2IS rims.
Enlighten me, what does ET stand for ? How about CB? Somehow the number "45" looks offset to me.
I think the main concern is probably the bore pattern - 114.3. I hope the 3IS doesn't update it just like CT & LS.
EDIT: just checked the Sewell site and it looks like 2IS and 3IS have the same bolt pattern 5-114.3 and so the 2IS OEM 17" wheels probably fit in 3IS. Just need someone to try the actual wheels on 3IS to confirm. Now it is a good news..
Old 07-18-13, 09:31 AM
Jlesz
Jlesz's Avatar
yeah my main concern is if the will fit over the big brakes on the is350
Old 07-18-13, 02:03 PM
magne
magne's Avatar
CB is center bore. The diameter of the hole in the middle of the rim. 60,1 mm in diamter on lexus.
ET is the offset. How many millimeters away from from the center of the wheel the surface that touches the brake disc is. 45 on the lexus wheels shows the offset in millimeters.
Try to google offset and you'll se an image that illustrates this.
The bolt pattern on the IS is 5x114,3. Not like the ct with 5x100.
2IS rims will fit 3IS. Not sure about the 350 version, due to different brakes from the rest of the lineup.
You'll may need a lower offset (about Et40) to make it fit.
Old 07-18-13, 03:06 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The IS250 can fit 16" wheels over the brakes, the IS350 can fit 17" wheels over the brakes.
The 17" 2IS wheels will fit the IS350 just fine, the specs are almost identical.
Jeff
PJSnow
06-21-19 05:44 AM
lovedasgs
10-09-17 12:27 PM
Brewdog
RX - 3rd Gen (2010-2015)
06-18-11 03:43 PM
jnguyen87
04-29-09 12:12 PM
Foodplz
Suspension and Brakes
02-26-09 07:36 PM
Quick Reply: oem 2IS WHEELS ON 3IS 350
