Bulbs replaced with LED bulbs...
Old 07-13-13, 01:05 AM
r0shiro
r0shiro's Avatar
Default Bulbs replaced with LED bulbs...
1) changed the front turn signal bulbs to LED bulbs - no DIY for this one, it doesn't require the removal of the bumper like the 2IS. This is straight plug and play.
2) replaced reverse bulbs with LED bulbs. No DIY needed for this one either...simply remove necessary clips to remove enough of the truck lining to see the bulb connector, twist, remove, replace, twist back on. =)
3) changed rear turn signal bulbs to LED bulbs. If there is a demand for a DIY I will create one. It's not the hardest install, fairly simple, but i can take a lot of the guessing game out for you guys if you'd like. Could also serve as a "replace your tail lamp" DIY. let me know peeps...
Note*** i did not install any type of resistor to avoid the "hyper blink" this install creates....but hey..its a lease and i dont want to mess with wiring if i dont "have" to.
Old 07-13-13, 02:35 AM
sl0519
sl0519's Avatar
Some photo of it please??
Old 07-13-13, 06:45 AM
kabgolf1
kabgolf1's Avatar
How about interior overhead lighting? Any changes there?
Old 07-13-13, 08:54 AM
dojoman
dojoman's Avatar
DIY write up would be great. I want to change overhead interior to LED but too chicken to mess around with brand new car.
Old 07-13-13, 11:18 AM
Appleman
Appleman's Avatar
Do you have the bulb types/numbers for the lights you changed?
Old 07-13-13, 01:23 PM
r0shiro
r0shiro's Avatar
@dojoman @kabgolf1 i didnt mess with the interior lighting. Exterior aesthetics are higher on my priority list so maybe thats why i havent even considered changing those...lol. I like daye that the housings are not shaded amber but then i see that amber bulb in there and it drives me crazy! I'll try to post some pics of it during the day (off) and at night (on).
DIY coming soon then... =)
Old 07-13-13, 01:26 PM
AndyL
AndyL's Avatar
Thanks to Ken in Minkara, I find this article is useful for prying the interior lighting in 3IS
http://minkara.carview.co.jp/userid/...9103/note.aspx
Part number wise -- it appears that the front interior light uses 3 T10/168/192 and the rear interior light uses 3 T10/168/192 as well.
Old 07-13-13, 01:28 PM
AndyL
AndyL's Avatar
Hi dojoman, it is not difficult as you think. If you look closely, there are indentation around the clear plastic. Make sure you use masking tapes and tape the screwdriver or use some prying tools from Sewell Lexus or your local dealership.
I haven't got the car yet but find the article in Minkara encouraging.
Old 07-13-13, 01:35 PM
r0shiro
r0shiro's Avatar
Default 99% sure... =)
the front turn signals are double filament bulbs - 7442A
the rear turn signal bulbs are single filament - 7443R
the reverse light bulbs - 941
I'm pretty sure this is right. A = amber, R = Red.
Old 07-13-13, 01:53 PM
AndyL
AndyL's Avatar
Hi thejaperu,
Thanks for the info. Can you confirm again the reverse light bulb is 941? Are you sure it is not 921?
What does it look like? I hope I can reuse the LED (921/T16) in 3IS that I have been using for the reverse light in 2IS.
Old 07-13-13, 02:08 PM
kabgolf1
kabgolf1's Avatar
That is great. What about the vanity mirror lights for a part number?
Old 07-13-13, 02:10 PM
r0shiro
r0shiro's Avatar
Hi thejaperu,
Hey AndyL
I'm having some work done on the car today so i cant get to the bulbs but i THOUGHT it was 941....maybe its 921? lol...
I remember, while i was installing them, "hey...these are the ones on my 2IS..." but then again...I'm wondering if both sizes are compatible....I'll let you know later when i get a chance to get to them. =)
Old 07-13-13, 02:11 PM
AndyL
AndyL's Avatar
I would think it is 168/T10 but need anyone who has the car to confirm.
Old 07-13-13, 02:49 PM
kabgolf1
kabgolf1's Avatar
Thanks. I am making notes so I can change those bulbs out when my car arrives. Still Waiting.....
Old 07-15-13, 11:03 AM
wildtigg3r
wildtigg3r's Avatar
Richie - Where do you buy your LED bulbs?
Quick Reply: Bulbs replaced with LED bulbs...
