3IS LSD Options: IS F / IS300 / FR-S
Old 07-02-13, 02:16 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Default 3IS LSD Options: IS F / IS300 / FR-S
Now that people are starting to take delivery, they may be interested in upgrading their differentials (hey, it could happen).
The 3IS IS250 uses the same differential as the 2IS IS250, which means that the complete pumpkin from an IS300 or FR-S is bolt-in for the car if you want an OEM T2 Torsen.
Gear Ratios:
3IS IS250 RWD: 3.73:1
3IS IS250 AWD: 4.10:1
1IS IS300 MT: 3.73:1
1IS IS300 AT: 3.91:1
Scion FR-S: 4.10:1
The 3IS IS350 RWD uses the same differential as the 08-09 IS F among others, as such swapping in a complete 10-13 IS F or 2013 LS460 F-Sport differential is possible, but you may want to keep the 3IS gearing as it is preferential.
Gear Ratios:
3IS IS350 RWD: 3.13:1
2IS IS F / LS460 F-Sport: 2.937:1
The 3IS IS350 AWD uses the same differential as the 2IS IS350. There are no factory options to swap into this, you will need to look into something like a Quaife or similar.
Jeff
Jarraj (01-18-18)
Old 07-02-13, 02:37 PM
Hoovey689
Forum Moderator
Hoovey689's Avatar
Folks will be happy. Thanks for sharing
Old 07-02-13, 03:03 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Question
Jeff,
Great Info..!!!
Are they using the same 08-09 IS-F "ELSD" Differential in both the IS350 F-Sport w/8 speed tranny and Regular IS350 w/6speed tranny ???
Being that the 350 F-Sport RWD now has 8 gears.. I thought they would have two different diffos..
~ Joe Z
Old 07-02-13, 03:13 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
I didn't list any AWD info since there are no interchangeable factory LSD's. I only listed RWD information.
AWD IS350's use the same ratio as last year, 3.769:1.
Jeff
Old 07-02-13, 03:24 PM
LexFather
Guest
Posts: n/a
Thanks for the info!
Old 07-02-13, 04:42 PM
Joe Z
Joe Z's Avatar
Lightbulb
Jeff
Jeff,
My question was just RWD specific... (no mention of AWD)
Just realized the RWD IS350 Base pkg & F-Sport pkg are both rocking the 8 Speed
(I've only been "reading up" on the F-Sport)
LoL
Thanks
~ Joe Z
Old 07-02-13, 05:31 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Sorry I didn't see that you had said F-Sport. To confirm what you said, all RWD IS350's have the 8-speed and 3.13:1.
Jeff
Old 07-02-13, 06:35 PM
NotnFsport
NotnFsport's Avatar
thanks for the info does the 3IS 350 utilize an Elsd ? so theres some benefit for 08/09 ISFs with the 3.13:1 ratio? i remember some people swapped out with a 2IS 350 diff and the benifits werent there.
Old 07-02-13, 07:16 PM
Nigel-JDMParts
Nigel-JDMParts's Avatar
Great Info!!
Thank You Jeff.
Old 07-02-13, 10:57 PM
AndyL
AndyL's Avatar
More gear ratio information in detail: (Look for 駆動装置)
The 8-spd in 2014 IS350 RWD
http://lexus.jp/models/is/specificat...350/index.html
The one in ISF
http://lexus.jp/models/isf/specifica...ons/index.html
後退 - reverse
第8速 - 8th gear....
turbo den
Performance
163
12-07-23 07:51 PM
Jeff Lange
08-18-23 07:46 PM
mthornto88
IS - 1st Gen (2001-2005)
06-21-18 08:52 PM
lexi90
10-03-16 09:35 AM
Quick Reply: 3IS LSD Options: IS F / IS300 / FR-S
