3rd Generation - Lexus IS 250/300h/350 Info & Specs
Old 01-22-13, 11:47 AM
Received 2,097 Likes on 1,360 Posts
wow, so only an inch smaller in l/w/h than the GS.
Old 01-22-13, 12:04 PM
4TehNguyen
4TehNguyen's Avatar
GS is
180mm longer length
30mm wider
40mm taller
50mm longer wheelbase
Old 01-22-13, 12:32 PM
pianospike
pianospike's Avatar
Originally Posted by natnut
Compare that with the 4th gen GS that donated the chassis for the new 3rd gen IS :
Length : 4580 (2IS) 4665 (3IS) 4850 (4GS)
Width : 1800 (2IS) 1810 (3IS) 1840 (4GS)
Height : 1415 (2IS) 1430 (3IS) 1455 (4GS)
Wheelbase : 2730 (2IS) 2800 (3IS) 2850 (4GS)
Included for interest the Infiniti Q50 dimensions :
Length : 4783
Width : 1824
Height : 1443
Wheelbase : 2850
BMW 335i dimensions:
Length: 4635
With: 1811
Height: 1430
Wheelbase: 2809
So it looks like the 3IS is slightly more than an inch longer, has a slightly shorter wheelbase than the 335i, but practically identical width and height. Unladen curb weight on the 335i sedan is 3,545 lbs.
Old 01-23-13, 05:10 AM
spwolf
spwolf's Avatar
Originally Posted by EZZ
Curb weight: 3,795 (GS 350, RWD); 3,527 (2IS 350, RWD);
This means the 3IS should have around 3650 as the curb weight. It may not be any faster than the current iterations even with the 8 speed.
last night i found info about weight - it is extra 20kg, 45lbs basically. I forgot now where i found it, but it was a quote from head engineer about performance that ended up as explanation on how they tried everything to reduce weight of new model.
it was "20kg motor for motor" basically. So it should be less than 3600 for 350.
Old 01-23-13, 05:18 AM
4TehNguyen
4TehNguyen's Avatar
the 4GS even with all the changes weighed 50 lbs less. Assuming that 45 lbs extra is true, makes sense since the car grew a couple inches
Old 01-23-13, 05:58 AM
spwolf
spwolf's Avatar
yes, but as you say, 3GS did not grow in size.
Old 01-23-13, 08:32 AM
dmk08
dmk08's Avatar
So will there not be a 2014 IS-F?
Old 01-23-13, 09:04 AM
4TehNguyen
4TehNguyen's Avatar
it will be a carryover from 2013. Wont have the new body and redesign. Same with the IS-C
Old 01-23-13, 09:57 AM
pianospike
pianospike's Avatar
Latest Motortrend article is showing 3,700 lbs for curb weight. I hope it is wrong.
http://www.motortrend.com/roadtests/...t_first_drive/
Old 01-23-13, 10:43 AM
4TehNguyen
4TehNguyen's Avatar
meh 50 lbs gained is a good trade off for 3 inches of extra legroom.
Old 01-23-13, 11:09 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
IS Convertible & IS F are carry over for 2014.
Old 01-23-13, 11:11 AM
spwolf
spwolf's Avatar
it clearly says it gained 50lbs from same equiped IS350.
Old 01-23-13, 12:15 PM
spwolf
spwolf's Avatar
Furuyama-san claims his team “tried to reduce the weight as much as possible [with new IS], but engine to engine comparison, the new one is about 20kg heavier than the old one”.
here is the quote, found it.
http://www.caradvice.com.au/209810/l...agon-rejected/
Old 01-23-13, 12:33 PM
EZZ
EZZ's Avatar
Two sources confirm about 50 lbs. Thats awesome. I bet the 1/4 acceleration will be a bit better as the 8 speed should negate any penalty for weight at 50 lbs. Better rear seat room with no speed penalty = WIN!
I'm liking this car a lot now.
Old 01-23-13, 12:36 PM
4TehNguyen
4TehNguyen's Avatar
weight gain was to be expected with the car growing 3 inches over the 2IS. With the gain only being 45-50 lbs its obviously they applied weight reduction like they did for the 4GS which lost 50 lbs.
Quick Reply: 3rd Generation - Lexus IS 250/300h/350 Info & Specs
