Hard brake pedal after sitting overnight... help?
Old 07-02-15, 01:51 AM
Fizzboy7
Fizzboy7's Avatar
Default Hard brake pedal after sitting overnight... help?
Has happened twice now. After car sits overnight, the brake pedal is hard as a rock when depressing it to start the car. Once the motor runs, all is fine. Also fine when driving. No leaks on the ground as far as I can see. Brakes are original with plenty of pad left according to the dealer at my last service (I'm at 40k miles). Is this something related to a brake boost leak or??? Not dealt in this area before and am out of warranty.
Thanks for any suggestions.
Old 07-02-15, 06:42 AM
Zynthe
Zynthe's Avatar
Your brakes lost compression. Happened to me on my 1IS before. Do you step on the brakes after the engine is off? That could be one reason.
Old 07-02-15, 06:43 AM
scott1256c
scott1256c's Avatar
It has happened to me in the past. Not regularly. I don't think I'd get too concerned just yet. You say twice now. How far apart between? How many times would you have run the car in between without experiencing the hard brake pedal? It goes away when, as soon as the car starts, i.e. the pedal softens up before you even get it out of park? Or a few moment/seconds/minutes thereafter?
Old 07-02-15, 07:33 AM
redspencer
OG Member
redspencer's Avatar
Hmmm....this is an interesting thread as I have the same issue. I noticed that my 2IS has been behaving this way on cold starts (time-wise not temperature-wise) for about a year now.
I used to be able to press the brake pedal all the way down before starting my car in the mornings but nowadays, the brake pedal has about a 1/2" play before coming to a complete stop and will remain that way until I start the engine up. The brake pedal and pressure behaves as expected throughout the rest of the drive.
So far I'm still alive and haven't crashed due to a brake system failure.
Old 07-02-15, 08:07 AM
cquence
Former Sponsor
cquence's Avatar
Going with what Zynthe has mentioned, loss of compression, once your engine is off, this cuts power assistance to the brake master cylinder; which leads to a stiffer or harder pedal feel.
"If the vacuum fails because the engine stops, for example the brakes still work because there is a normal mechanical link between the pedal and the master cylinder. But much more force must be exerted on the brake pedal to apply them."
More about master cylinders and power assistance can be found here:
http://www.howacarworks.com/basics/h...g-system-works
Another example is your steering. Modern cars have power steering. When your vehicle is on, it is easy to turn the steering wheel. When it is off, it is much harder. Same technology, just different purpose.
Hope this helps but if it is not the case, definitely have your master cylinder checked out for leaks and other points of failure.
Old 07-02-15, 12:51 PM
Gville350
Gville350's Avatar
Nobody has found the root cause of this "issue" and it is a known gremlin that does pop up and then just disappear as quickly as it came. My car has done this 3-4 times in 4 yrs. Does catch you by surprise, but it is not dangerous; no one has posted any ill effects of their cars braking after having experienced this "issue."
Old 07-03-15, 09:42 PM
Fizzboy7
Fizzboy7's Avatar
It happened again today. It's been very hot and humid here in L.A. and so far this latest batch has been during the heatwave. Has anyone else noticed the weather conditions when it happened to them?
I should also add, one of my original concerns was I wouldn't be able to start the car if the pedal can't be depressed. How much motion is required for the sensor to be triggered in order to start the car? It feels like I have barely moved it at all when this happens, yet the car thankfully starts.
Old 07-04-15, 12:04 AM
600rr05
600rr05's Avatar
its happened to me a few different times. not enough to make me want to take it in.
Old 07-04-15, 06:58 AM
Bichon
Super Moderator
Bichon's Avatar
Yes, for me it has only happened a couple times, always in snowy winter weather. I initially thought it might be related to excessive activation of the ABS system.
Not far. I've never had a problem starting the car due to a firm pedal.
Old 07-04-15, 04:59 PM
Cdawg250
Cdawg250's Avatar
I noticed if you step on the breaks w/ the car off the breaks tend to get stiff..if that helps
daredeil95
09-11-18 08:36 PM
Jwild909
05-04-16 01:00 PM
Lexus082
Suspension and Brakes
06-21-11 05:39 PM
en11871
04-17-10 05:32 PM
en11871
01-22-08 03:53 PM
Quick Reply: Hard brake pedal after sitting overnight... help?
