IS350 one spark plug black other 5 ok does anybody know why?
Old 06-05-15, 07:56 PM
MWIS350
MWIS350's Avatar
Default IS350 spark plug black does anybody know why?
IS350 spark plug is black does any know why? performance is lacking.
Old 06-06-15, 09:57 AM
MWIS350
MWIS350's Avatar
Try to google they say too lean. Not sure what's the cause?
Old 06-06-15, 01:27 PM
hirsch2is
hirsch2is's Avatar
Could be bad gas. I see this a lot at my dealer because there are a lot of shady gas stations on the reservation near my work. I would assume you wouldn't be dumb enough to accidentally put diesel in it...
Old 06-06-15, 06:17 PM
MWIS350
MWIS350's Avatar
I fill 93 at BP and sometime 92 at other gas station. I will try new MAF Sensor.
Old 06-06-15, 10:08 PM
synrgy350
synrgy350's Avatar
Black spark plugs are a result of rich running not lean, lean plugs are white due to running hotter. Rich plugs are carbon fouled which means too much fuel is going into that one cylinder. Not sure why though, perhaps the injector is no spraying correctly?
Old 06-06-15, 10:21 PM
NickTee
NickTee's Avatar
That plug looks fine. Now if that black soot was on the tip/center electrode, that'd be a sign of the cylinder running rich and it would be concerning if it was doing that only on a single cylinder.
If you're at 100,000 miles or more and haven't replaced the plugs, replace them.
Old 06-06-15, 10:50 PM
MWIS350
MWIS350's Avatar
I also check other plug and all are black. Just order new MAF sensor hope it help.
Old 06-06-15, 10:51 PM
MWIS350
MWIS350's Avatar
My car is 77k miles. I change about a month ago.
Old 06-06-15, 10:52 PM
NickTee
NickTee's Avatar
Your plugs are fine if they look like the one pictured. Ordering a MAF isn't going to do anything other than waste your money. Just make sure your plugs are torqued correctly.
Old 06-06-15, 11:05 PM
MWIS350
MWIS350's Avatar
thank for information. How about new ECT - Engine Cooling Temperature Sensor will that help if car feel lacking performance?
Old 06-07-15, 09:26 AM
NickTee
NickTee's Avatar
The first thing you need to do is verify that there's an actual abnormality in performance versus what you perceive to be an abnormality. Whether you have access to a track, a dyno, or just straight up try 0-60 times and compare them to what the car would normally run.
Old 06-07-15, 11:04 AM
hirsch2is
hirsch2is's Avatar
Ah I didn't see the plug picture before. That looks fine. If you don't have a check engine light on you most likely don't have any problems. Also the weather is getting warmer which could result in a little less performance.
Old 06-07-15, 05:12 PM
smokyis350
smokyis350's Avatar
Looks similar to my plugs at ~60k.
Old 06-07-15, 07:57 PM
MWIS350
MWIS350's Avatar
Car lack performance 0-60. I might try 1/4 miles time at track. Test drive wife IS250 and her car seem smoother good power to get around.
Old 06-07-15, 09:21 PM
NickTee
NickTee's Avatar
Did you verify that there are no existing or stored codes? Also that all the spark plugs are torqued to spec?
Quick Reply: IS350 one spark plug black other 5 ok does anybody know why?
