Deep review on ebay Headlight - New Version
Old 06-21-15, 04:57 PM
  #121
Epic123
Epic123's Avatar
Just installed the headlights today with new xenon depot Xtreme 5000k HID low beams. Looks very good and installation went well.
At first, the HID was not working until figured out that the relays that was included in the kit was the problem. After removing the relays, the HIDs worked fine. So if anyone is installing Xtreme HIDs from xenon depot, no need to use the relays. The lights do not flicker.
Will post up some pictures tonight.
Thanks again for your help whitebeast and I really appreciate you stopping by to help me troubleshoot the HID situation!
Epic123 is offline
Old 06-21-15, 09:17 PM
  #122
Epic123
Epic123's Avatar
Before picture of passenger side headlight. Yellow coloring is not as bad as the driver side.
Bumper removed. Very yellow coloring and hazy headlights due to moisture inside.
Headlight back cover came with a pre-drilled hole and grommet for retrofit HID kits (very convenient). I had to make a small cut because one of the HID connector is too wide to pass through. I used a kitchen knife.
HID retrofit kit installed
This is what it looks like on the inside with H1 high beam and H7 low beam.
Installation complete. This was taken at about 3PM.
Low beam OFF, Fogs OFF, High beam with LED on as city lights. Taken at about 7:30PM. still a bit bright out.
Low beam ON, LED ON, Fogs ON. HID from the previous owner who apparently had two different type of ballast lol. Will upgrade fogs to matching lights in the near future when I decide to install body kit and restore the fog light lens.
Side view
9PM. All lights ON
Engine ON. Light switched OFF. Light is from High beam.
Low Beam projection
Epic123 is offline
Old 06-21-15, 09:21 PM
  #123
Epic123
Epic123's Avatar
Any recommendations for swapping out the high beam? I'm not a fan of the yellow lights during the day haha. Thinking about buying an LED H1 bulb.
Epic123 is offline
Old 06-22-15, 11:06 AM
  #124
Joelseff
Joelseff's Avatar
I want this so bad but VIPMOTOZ is out of the black ones for the time being. looks like he only has the chrome housed one with smoked lenses-not my cuppa tea. There are a bunch of other ones from ebay but they look like the old ones.
Joelseff is offline
Old 06-22-15, 11:45 AM
  #125
cruzck
cruzck's Avatar
Default Deep review on ebay Headlight - New Version
Side view
9PM. All lights ON
Low Beam projection
Is the only way to run the LED DRL is to have high beams on? There's no way around that?
cruzck is offline
Old 06-22-15, 12:43 PM
  #126
Epic123
Epic123's Avatar
The highbeam light will turn on at 50% brightness when the engine is on acting as DRL. When you turn the light handle one click to the city lights, the LED light turns on while the high beam stays on. When Low beam is on, the LED stays on and the high beam turns off. If you want LED to be on as DRL when engine is on, rewiring is needed. Theres another thread that can show you how.
Without rewiring, the car will default to use high beam light as DRL when the engine is on. When the light switch is set to auto, during the day the high beam will be on while at night the low beam and LED will be on. Not a big deal to me.
Epic123 is offline
Old 06-22-15, 09:00 PM
  #127
whitebeast
whitebeast's Avatar
The highbeam light will turn on at 50% brightness when the engine is on acting as DRL. When you turn the light handle one click to the city lights, the high beam light turns off and the LED light turns on. Ill verify later. LED light stays on when low beam is on. If you want LED to be on as DRL when engine is on, rewiring is needed. Theres another thread that can show you how.
Without rewiring, the car will default to use high beam light as DRL so you cant get LED on auto. Not a big deal to me.
I could help you turn off DRL (highbean turn on at 50%) Text me.
whitebeast is offline
Old 06-22-15, 10:31 PM
  #128
smokyis350
smokyis350's Avatar
You have to remove the headlights to change the bulbs?
When will he have the black one in stock?
smokyis350 is offline
Old 06-22-15, 11:20 PM
  #129
Epic123
Epic123's Avatar
Can probably get to the bulbs without removing the headlight by removing the air filter for the passenger side and the washer fluid tube on the driver side to access the headlight back cover. Will probably be a pain in the *** though since there are 6 screws and very little room to work with so i'm hoping none of the lights fail lol. But removing the headlights is actually quite easy. I was intimidated at first but just follow the videos/guides and it can be done in less than 15 minutes once you get comfortable.
Epic123 is offline
Old 06-23-15, 04:23 PM
  #130
Kvs_350
Kvs_350's Avatar
I just returned my to vipmotoz great service! They should have a set for available soon haha looks great
Kvs_350 is offline
Old 06-23-15, 08:48 PM
  #131
MWIS350
MWIS350's Avatar
Default How come you return your?
How come you return the headlight?
MWIS350 is offline
Old 06-23-15, 09:49 PM
  #132
smokyis350
smokyis350's Avatar
^ +1 would like to know also
Old 06-23-15, 10:07 PM
  #133
MikeFoxx
MikeFoxx's Avatar
+1 over here
MikeFoxx is offline
Old 06-23-15, 11:20 PM
  #134
Joelseff
Joelseff's Avatar
They told me end of July
Joelseff is offline
Old 06-24-15, 01:37 AM
  #135
cruzck
cruzck's Avatar
I've noticed that the eBay ones are pretty much the design replicated from the ones by Spyder Auto. Are they the same? If not, what's difference? Build quality?
cruzck is offline
Quick Reply: Deep review on ebay Headlight - New Version
