Unplugged Battery now check VSC
Old 05-04-15, 08:28 PM
synergy141
synergy141's Avatar
Default Unplugged Battery now check VSC
Hi, I unplugged my battery on my 06 is250 and after I hooked it back up I fired the car up. It ran for a second then died. I pushed the start button again and it fired up just fine and it runs good. Only thing is that the "VSC" light came on and won't turn off. This happened a couple weeks back and the light still hasn't turned off after going through all the drive cycles.
Any ideas?
Old 05-05-15, 08:57 AM
ISPearl08
ISPearl08's Avatar
Hmm the same thing happened to my 350 when changing to a new battery. For me it will go away after driving it a couple times. Maybe try unplugging the terminals again and try again.
Old 05-08-15, 04:52 AM
Icy350
Icy350's Avatar
You can always try to get a code from your local auto
Zone.
Old 05-08-15, 05:14 AM
Bichon
Super Moderator
Bichon's Avatar
Icy is right. Read the codes and find out why the check engine light is on.
Also, are you leaving out a potentially relevant part of the story? Why did you disconnect the battery in the first place?
Old 05-09-15, 07:58 AM
whitebeast
whitebeast's Avatar
+1 for obd2 code
gsssss
01-23-23 09:57 AM
ls400geek
05-21-16 05:53 PM
dmrinehart
05-31-14 07:33 AM
boss22
05-02-12 04:58 PM
Quick Reply: Unplugged Battery now check VSC
