Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Anyone install figs front lower rear mount #2???
Thread Tools Search this Thread
Old 04-23-15, 01:31 PM   #1
avinad
Trader Score: (5)
@cocodrilo88
Default Anyone install figs front lower rear mount #2???
Hey just got the figs front lower rear mount to help with the toe issues and sloppiness in the oem bushing. Has anyone on here done the install themselves? If so how difficult is it? I have all tools necessary but just want input on whether it's a pain or hassle to install or if it's somewhat easy. Just debating on whether to pay for install or just diy
Thanks in advance
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
avinad is offline   Reply With Quote
Old 04-23-15, 02:30 PM   #2
WylieKylie
Trader Score: (1)
Did you get just the bushings or the bushings installed in brackets? That makes a pretty significant difference on the difficulty of the install.
Installing the brackets is a straightforward nuts and bolts affair. Pressing the old bushings out and the FIGS bushings into your brackets is another story.
WylieKylie is offline   Reply With Quote
Old 04-23-15, 02:53 PM   #3
avinad
Trader Score: (5)
@cocodrilo88
Oops sorry I got the whole bushing and bracket together so it'll just be bolt on
Old 04-23-15, 04:31 PM   #4
boystar22
Trader Score: (0)
boystar22's Avatar
boystar22 boystar22
Took about two hours to install mine on a Saturday morning taking my time. I needed a pry bar and a second person to pry the LCA down to slide the old bushings off and put the new ones on but other than that it was easy. They handling is different as the understeer in reduced but the car doesn't ride any rougher than before (I have f-sport springs and shocks).
__________________
2009 IS 250 SGM RWD: F Sport Shocks - F Sport Springs - F Sport Sways - Trunk Spoiler - Roof Spoiler - F Sport Intake - Figs LCA Bushings - Sport Pedals - Smartcard Key - Steering Damper - 2011+ Steering Wheel Controls - Yellow Fogs - 30% Window Tint - 70% Windshield Tint - Weathertech Floormats
boystar22 is offline   Reply With Quote
Old 04-23-15, 04:35 PM   #5
avinad
Trader Score: (5)
@cocodrilo88
Quote:
So you didn't take off the complete arm off?? I noticied it won't slide straight off as it'll hit the block or whatever it is that's there. So you just used a pry bar to lower the arm past that piece that won't let the bushing slide off?
Old 04-27-15, 02:44 AM   #6
boystar22
Trader Score: (0)
boystar22's Avatar
boystar22 boystar22
Quote:
Sorry for the late reply; correct I just left the arm on the car and pried it down far enough to slide the old ones off and the new ones on.
Old 04-28-15, 02:16 PM   #7
WylieKylie
Trader Score: (1)
^ Same here, I left the arms on the car and used a persuader to get the job done.
Old 04-28-15, 02:52 PM   #8
andper10
Trader Score: (0)
Correct. I used the spare tire wrench to pry with and it will do, but I also had to have someone else slide the old bracket out and the new bracket in while I was prying. A larger pry bar might make it easier to do by yourself.
andper10 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wheel Alignment jadeboy IS F 10 04-29-15 01:00 PM
Biggu's "Build" Thread Biggu Build Threads 62 04-23-15 07:46 PM
BIG suspension install --- need advice MrHarris Suspension and Brakes 10 03-09-15 08:20 AM
Those with Figs Poly Lower Control Arm Bushings and Caster Arm Bushings... Ahheck01 Suspension and Brakes 8 01-12-15 06:27 PM
Just got my FIGS Heatshield! Boostless GS - Second Generation 26 11-24-13 09:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
