F sport exhaust and torque loss
Old 04-04-15, 08:21 PM
deestyle28
deestyle28's Avatar
Default F sport exhaust and torque loss
Probably a dumb question but couldn't find an answer when doing a search. I have an F sport exhaust on my car for about a year now and I noticed that when I initially accelerate I don't really feel the torque I use to have when my car had a stock exhaust. When my car was stock acceleration wasn't bad but with the exhaust on I feel like I have to gas it a lot more just to get the car going. Is this normal? My mpg went from 25 to 21 from the install probably due to accelerating more.
Feedback greatly appreciated!
Old 04-04-15, 09:18 PM
smokyis350
smokyis350's Avatar
Try resetting your ECU or unplug the battery.
Regardless, the IS350 is pretty torqueless too on the low end. I have to step on it pretty hard compared to German cars like 335
Old 04-04-15, 09:22 PM
knguyenk
knguyenk's Avatar
Usually an aftermarket exhaust will increase the torque in the middle of the rpm band (for the 2IS), so it's interesting that you are observing these issues. I would double check for leaks in your exhaust and reset your ECU by pulling the negative terminal off the battery for a good 5 - 20 mins like what smoky mentioned. The car will relearn your driving habits and can probably iron out those issues if it's a computer related issue.
Old 04-06-15, 06:43 PM
Mike_1GO
Mike_1GO's Avatar
IS350 does feel a bit torque less down low but above 3000rpm they pull hard
Old 04-08-15, 06:08 PM
Gville350
Gville350's Avatar
N/A vehicles need some back-pressure; it is likely the powerband (with the introduction of larger exhaust piping) moved around some on you. I'll hopefully maintain my lower-end torque after adding my PPE headers here soon. We'll see!
Old 04-08-15, 06:16 PM
jbone29
jbone29's Avatar
I've had my Fsport exhaust on for about three weeks and I was thinking the same thing. Doesn't seem to take off like it did when I had stock exhaust on it. I thought it was just me,haha. I guess I can try resetting the ECU also.
Old 04-08-15, 07:06 PM
redspencer
OG Member
redspencer's Avatar
Gville350 is correct. I immediately noticed a lack on instant low-end torque when I briefly swapped out my stock exhaust for the drone-heavy M2 exhaust.
I might be the minority here but I feel that the low-end torque of the 2GR-FSE is fantastic for what it is (3.5L V6). The 2GR-FSE with the D4-S is capable of transmitting 90% of its total torque output from as little as 2,000 RPM which is a pretty impressive feat for a naturally aspirated V6 engine (IMHO).
Old 04-08-15, 07:21 PM
smokyis350
smokyis350's Avatar
That is hard to believe that the IS350 has ~250 torque at 2k rpm. Feels like it has 50lb-ft of torque at those RPM.
My friend's Corolla that has ~120 torque feels like it has a lot more low end power than the IS350.
Old 04-09-15, 03:27 AM
jeepandlex
jeepandlex's Avatar
yeah, when you stick a bigger diameter exhaust on a stock car, you'll loose a little seat of the pants feel....the powerband has moved up in rpm. At WOT you'll gain some power.
Old 04-09-15, 04:46 PM
iRock
iRock's Avatar
I've been driving with it since day one. I had no idea.
Old 04-09-15, 04:53 PM
getafewliv
getafewliv's Avatar
I am going to say I can feel the same thing when I put on my Invidia midpipe. I don't think I noticed any difference when I had put on my M2 exhaust though.
Since the Invidia pipe, it feels like when I hit the gas it has to really build the RPMs before it takes off. It's quite annoying, especially after going around corners. It's making me have to use the paddle shifters to keep the car from shifting up.
I have also noticed a decrease in gas mileage, but I figured that could have something to do with driving harder to hear the car growl.
Old 04-09-15, 09:19 PM
hirsch2is
hirsch2is's Avatar
Pretty much anything that improves airflow will move the torque band higher I've learned. I learned this big time swapping the intake manifold on my e36 and exhaust on an older is
Old 04-10-15, 12:28 PM
nfordhk
nfordhk's Avatar
Too big of an exhaust with no back pressure will cause loss of power too.
Old 04-10-15, 12:32 PM
Hoovey689
Hoovey689's Avatar
I'm just shocked you still have the IS! Heard you talking about different vehicles over the years!
Old 04-13-15, 12:00 PM
deestyle28
deestyle28's Avatar
jbone29, let me know if you feel any difference when you reset the ECU! Thanks!
Quick Reply: F sport exhaust and torque loss
