Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
carbon build up recall
Thread Tools Search this Thread Display Modes
Old 04-04-15, 06:16 PM   #1
yandeltx
Trader Score: (0)
Default carbon build up recall
My daughter has a 2008 IS250 AWD with 79K miles. She is having intermittent idling issues. This happens once or twice a week while sitting at a stop light. She has had the car for 3 yrs, it had like 45k on it when she bought it. My question is, is this something that could be a bi-product of the carbon recall? I just ran across this recall today while spending time on this forum. Evidently the carbon issue is somewhat widespread since Lexus came out with a recall. Anyway, can anyone give me any advice on how and when I should start worrying about the recall? How accommodating is Lexus when it comes to the recall.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
yandeltx is offline   Reply With Quote
Old 04-04-15, 07:01 PM   #2
Kasim
Trader Score: (0)
start having the same issues,
i posted Here
May find something.
Kasim is offline   Reply With Quote
Old 04-28-15, 02:37 PM   #3
Tajai7
Trader Score: (0)
I'd start worrying about this now before it stalls out completely and she's in rush hour traffic or at a busy intersection. Also, note that I think Lexus will only cover this issue under the power train warranty.
I'd get it into the dealership now and see if they can pull any diagnostic error reports of the cylinder misfires. If they can, then you'll likely get some new pistons and valve rings. If not, they'll just do a top engine clean.
If you're outside of warranty, I'd look into Walnut Blasting too as an option if any local shops offer it. It's a pretty new process that is not offered by Lexus but works great at cleaning out the intake valves.
Tajai7 is offline   Reply With Quote
Old 04-28-15, 02:49 PM   #4
tomiv9
Trader Score: (0)
It is not a recall, it is TSB. So the dealer has to verify the symptons before they will perform it. There is a 9 year/unlimited miles timeframe to get the TSB done though, so if your close you should bring it in sooner then later. Sometimes it takes a couple of visits before the dealer can verify it.
__________________
2009 IS250 AWD
tomiv9 is offline   Reply With Quote
Old 04-28-15, 07:34 PM   #5
nosurprise
Trader Score: (0)
nosurprise's Avatar
What kind of idling issues is she having? Since it's not a recall (Lexus is calling it a Customer Support Program CSP basically extending the warranty on this particular issue for 9 years from the in-service date), the dealership will have to verify there is a problem before they will fix the problem. With a safety recall, Lexus will replace the parts whether the symptoms are present or not.
nosurprise is offline   Reply With Quote
Old 04-29-15, 06:13 AM   #6
Tanoshii
Trader Score: (0)
Tanoshii's Avatar
Yeah, the Toyota Yaris has a "Field Action" (new name for our TSB fixes lol) similar to this. If there are any misfire codes, it says to have the head removed and a full cleaning / valve job done. But for people out of the coverage period, we've been trying the Toyota injector / fuel system cleaning service and have been having great results so far. Haven't tried on an IS-X50 yet though.
Do you have a DTC set? (engine light). Doesn't look like it is a requirement to have the service done from Lexus though because it says "one or more of the following conditions" on E-TAS.
From E-TAS Lexus, if you want to see if your car qualifies:
Some 2006 – 2010 model year IS250 vehicles may exhibit one or more of the following
conditions:
 MIL “ON” DTC P0300, P0301, P0302, P0303, P0304, P0305, and/or P0306.
 Runs rough after coming to a stop with the engine at operating temperature.
 Runs rough with engine misfires present after a cold soak startup.
APPLICABILITY:
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2006-2010 IS250
PRODUCTION CHANGE INFORMATION:
This TSB applies to vehicles produced BEFORE the Production Change Effective VIN shown below.
MODEL PLANT DRIVETRAIN PRODUCTION CHANGE EFFECTIVE VIN
Tahara 2WD JTHBF5C2#A5111618
4WD JTHCF5C2#A5038287
2WD JTHBF5C2#A2095102
IS250
TMK
4WD JTHCF5C2#A2032832
Basically, what's being done is roughly the same it seems though :3
The service for the issue is get the engine to operating temp, removing the spark plugs, disconnecting the starter and removing the intake air surge tank. Then, pouring 1oz of upper engine / fuel injector cleaner down the spark plug tubes, covering with rags, jumping the starter relay and cranking it for 5 seconds. Then, let the stuff soak for an hour.
Then... use a generic lubricant in the tubes, rotate the crank pulley clockwise two turns to clear out the lubrication, then crank again for 5 seconds and wait another hour.
Then... reassemble, drain and refill oil. After that, start and immediately test drive for a min of 15 minutes.
Finally, drain oil, refill again and give it a new filter... and check for codes :3
Tanoshii is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fuel smell '08 ISF BLKLBL IS F 27 12-30-14 04:41 PM
Carbon build Leowaxx IS - Second Generation 1 10-15-14 04:39 PM
Carbon build up recall help DaneAustin IS - Second Generation 13 06-02-14 12:17 PM
Valve spring recall...miles later dutchie350 IS - Second Generation 2 04-28-14 12:45 PM
2008 GS valve spring recall Ironman50 GS - Third Generation 8 02-03-14 05:07 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
