Help is Much Appericiated! [Transmission problems]
Old 03-17-15, 04:48 PM
oyeitsdean
oyeitsdean's Avatar
Default Help is Much Appericiated! [Transmission problems]
I own a pass down IS250 06 with 170k Millage the engine seem running just fine but My VSC Light came on and goes away on its own. When I drive It doesn't seem to go pass the 3rd Gear. If I was to drive pass 50mph it would be revving at 4-5k rpm. 5-6 gear seem to not be working I got the Code Check out at a local mechanic shop for free and got P0761 solenoid C stuck off, P0751 solenoid A stuck off. He quoted me at 3K for a transmission rebuild, he also erase the check engine light which gave me a temporary fix because my car seem to be running okay...But i know its a matter of time before the vsc+ engine light comes on again. Ive read few thread from people that had solenoid replace but the problem kept reoccurring. I don't think I want to go that route. Anyone experiencing the same problem with a Fix? or is it time to save up for another transmission. Sigh..
Old 03-17-15, 06:50 PM
Gville350
Gville350's Avatar
I'd bypass the rebuild and just look for a lower mileage replacement trans.
Old 03-17-15, 07:26 PM
idoke1
idoke1's Avatar
^^I'm with Gville350. Look for a used low miles transmission.
Old 03-18-15, 10:14 AM
oyeitsdean
oyeitsdean's Avatar
Thanks for the reply. But Im gonna just do a trade in for a Honda Civic . Since Im going broke from pouring money in to it. maybe in a year or two Im swoop up the new is250-350.
Old 03-18-15, 12:12 PM
Gville350
Gville350's Avatar
^Let us know how much they will offer you; hopefully the trans doesn't act up on the day you bring it!
Old 03-18-15, 02:35 PM
iRock
iRock's Avatar
This is what I would do. Maybe not a civic but trade it in for sure!
Old 09-03-15, 04:10 PM
TestyMac
TestyMac's Avatar
Any update on these solenoid replacements? My gearbox doesn't shift past 3rd when the lights two solenoid C and D codes are on. But shifts fine when I manually do it.
The fact that two solenoids are giving errors but the gearbox seems to be okay mechanically, would it suggest a wiring or tcm issue?
Old 10-23-15, 02:54 PM
MWIS350
MWIS350's Avatar
Originally Posted by mattsranch
115K miles. I have this issue, Error code P0761, only shifts from 1 to 3. So far I have removed transmission pan, cleaned, new filter, refill, checked solenoid C to be ok. But issue still persists.
Anyone know the correction for this issue short of a new transmission?
Do you have picture to show which solenoid is which when taking out transmission pan?
My car is at dealer now till Monday. I got code P0894 and P0761 two solenoid are bad. When I check at Oreily Auto parts. One a while it stuck on 3rd gear until I switch to S mode.
Old 10-24-15, 06:50 PM
hirsch2is
hirsch2is's Avatar
you could have a wiring issue that is causing this. two solenoids at once seems a little weird. either that or a computer issue
Old 04-17-17, 07:33 PM
gs300tube
gs300tube's Avatar
Default Gs
did yu het solomoid problem fixed. I'm having same issue
lexuslivin
12-05-22 10:08 AM
Grovecity
03-02-16 05:15 PM
4TehNguyen
11-02-14 07:41 AM
Taylay
04-17-14 07:55 PM
dvsasian
05-05-04 10:10 AM
Quick Reply: Help is Much Appericiated! [Transmission problems]
