Navigation screen at night
Old 03-07-15, 08:32 PM
punkrrrock
punkrrrock's Avatar
Default Navigation screen at night
I am having a problem and was hoping maybe someone here knows how I can fix it.
At night my navigation screen used to switch from white to black automatically. It no longer is doing this. Also at night my buttons around the navigation no longer are backlit. They all used to light up at night. My headlights still come on automatically at night so it seems the light sensor is still functioning... I have been trying to find any information I can about my problem and all I have found is people saying the cluster dimmer should not be turned all the way to the right and mine is not.
Thanks ahead of time for any advice on this.
My car is a IS350 2006
Old 03-07-15, 09:54 PM
LucianoLee
LucianoLee's Avatar
press Display--> Daytime (or something like that) its a little option on top right corner of the display after u get in Display setting
Old 03-08-15, 07:27 AM
Gville350
Gville350's Avatar
Have you adjusted the cluster illumination **** to FULL bright? If so, knock it down OFF of full bright.
Old 03-08-15, 07:51 AM
Bichon
Super Moderator
Bichon's Avatar
That was my thought as well, but the original poster states:
Old 03-08-15, 08:20 AM
Gville350
Gville350's Avatar
^Oops, reading the entire post owns me this morning. LOL!
Old 03-08-15, 12:47 PM
punkrrrock
punkrrrock's Avatar
I have been through all of the menu's in the navigation and have not found a "Daytime" option. Or anything similar.
Also I should note I have stashed a few things (DAC, 5v power supply, relays ect) inside the center console. I have been in and out of the center console cavity many times in the last month or so. Along with buttons around my nav not being backlit anymore the Park, Reverse, Neutral, Drive ect lights are no longer backlit.
There are 2 plugs that get plugged in under the shifter panel. One (small white plug) is for the seat heater/ac adjusters but there is also a larger black plug. I have always made sure they are both plugged in when I put everything back together but I dont know what the black plug is for? It seems that the black plug would be the only way the shift positions could be backlit?
Old 03-08-15, 07:49 PM
LucianoLee
LucianoLee's Avatar
It actually called "Day Mode".
Old 03-08-15, 11:18 PM
punkrrrock
punkrrrock's Avatar
I actually don't have that... it's just not there. Is it possible that was added in a later model? after 2006? As you can see to the left I have the cluster all the way dimmed out as well.
Old 03-09-15, 04:42 AM
Bichon
Super Moderator
Bichon's Avatar
It wasn't added later. My 2006 is from very early in the model year, both built and bought in 2005, and it has the "Day mode" button that LucianoLee photographed.
I suspect you don't have the virtual "Day mode" button because whatever electrical gremlin is keeping your shift position indicator and nav buttons dark is locking the unit into day mode, much as turning the instrument illumination to full brightness does.
Old 03-09-15, 08:25 AM
LucianoLee
LucianoLee's Avatar
That is weird! Mine is an 06 as well. Check again if you set yours at full brightness. I did that and forgot about it sometimes....
Old 03-09-15, 08:27 AM
LucianoLee
LucianoLee's Avatar
Where is your headlight switch option at? "Auto"? Try to set it to different ones and see what happen...
Old 03-10-15, 07:50 AM
punkrrrock
punkrrrock's Avatar
Yes everything still behaves the same no matter what position the cluster dimmer or headlight dial is in
Under the console there are 3 connectors. These are the only connections I have messed with. One for the seat heaters, one for illumination of P, R, N, D (which no longer works under any conditions). And one for the ash tray unit. I went back in there yesterday and made sure they are all snugly connected.
Old 03-10-15, 09:55 AM
Icy350
Icy350's Avatar
Are you sure yours is oem navi?
I have an 06 and mine has the day mode option as well.
Old 03-10-15, 11:30 AM
punkrrrock
punkrrrock's Avatar
Yes I am sure it is OEM.
I think what Bichon said is accurate, although not specific enough to resolve the problem:
"I suspect you don't have the virtual "Day mode" button because whatever electrical gremlin is keeping your shift position indicator and nav buttons dark is locking the unit into day mode, much as turning the instrument illumination to full brightness does."
I just noticed something that seems to complicate things further? In LucianoLee's picture his nav is set to "Day Mode" and his tactile buttons (AC/ Climate/ Defroster) are backlit. This seems to make things more confusing! Bah
Old 03-10-15, 12:11 PM
Gville350
Gville350's Avatar
Have you checked for any popped fuses yet?
Quick Reply: Navigation screen at night
