Check VSC, Traction Control, and Check Engine Lights on..problem?
Old 02-26-15, 08:39 AM
lucasalois
lucasalois's Avatar
Default Check VSC, Traction Control, and Check Engine Lights on..problem?
For the past 6 months every so often the "check engine" light and the light representing traction control being off come up on my dash. Also, on the little digital screen it says "check VSC" with the red triangle. The lights will disappear in a day or two and then come back a random amount of days later. Does anyone know what the problem is and is it serious? Car receives check ups fairly regularly but not in the last few months. I attached a pic of it, thanks for your help.
Attached Thumbnails Check VSC, Traction Control, and Check Engine Lights on..problem?-img_1241.jpg
Old 02-26-15, 10:01 AM
Sceanzo
Sceanzo's Avatar
Scan the PCM for DTCs
Old 02-26-15, 10:09 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
scan and get the codes....might be your gas cap....
Old 02-26-15, 11:11 AM
vicsis250
vicsis250's Avatar
This is a very well know issue that the IS has do a search for that subject there has been a lot of talk about this there is a so call easy fix that you can do yourself
Old 02-27-15, 05:58 AM
See5
See5's Avatar
I have the same issue , cleared the code two times and never came back.
For my case it is the MAF sensor. We should both try to clean it.
I couldn't find MAF cleaner in my country yet. But it is there in USA
Good luck
Old 02-27-15, 06:00 AM
See5
See5's Avatar
The code inside TIS program was:
C1201
brandon17
Maintenance
07-03-18 02:15 AM
NINAPOO24
ES - 5th Gen (2007-2012)
04-02-17 04:16 PM
kchow510
01-22-13 04:52 PM
stvIS250
10-23-09 08:10 AM
Quick Reply: Check VSC, Traction Control, and Check Engine Lights on..problem?
