stock wheels 265\40\18 ?
Old 05-15-15, 11:03 AM
Byprodrive
Byprodrive's Avatar
Originally Posted by carlos3366
the tires. So I'm thinking about getting two additional front stock wheels and use them in the rear.
I wanted to do this too as my rear tires last twice as long as the fronts without rotating them.
Problem is the height of the rear tires. Best size to go with is 245/40/18 all around but the shorter tire in the rear will make odometer higher than actual miles.
Old 05-15-15, 02:54 PM
andper10
andper10's Avatar
Will it be difficult to avoid rubbing during full lock steering with 235/40/18 Michelin PSS up front? I already have a heat gun but I'm not familiar with the technique mentioned. Was planning to get 235 front / 265 rear on stock rims the next time I get new tires for my 07 IS350. I'm concerned that the neutral handling balance I currently have with F-Sport sways might be thrown off if I do 225 front / 265 rear. I'm at stock ride height with no plans to go lower.
A set of FIGS #2 LCA bushings should fix that and pay for themselves with longer tire life if you plan to keep the car for a while, assuming they are wearing faster on the inside edges than the rest of the tire.
https://www.clublexus.com/forums/sus...0-duro-hp.html
Old 08-30-15, 05:53 AM
SeanIS350
SeanIS350's Avatar
Can anyone comment on this?
Anyone running Continental DWS 235/40/18 up front on stock rims? If so, does it rub?
Old 08-30-15, 12:25 PM
mike33
mike33's Avatar
Im running 235/40/18 bridgestone re760 on the front on stock wheels with zero rubbing. Im also lowered about 1.5" and have 10mm wheel spacers.
Old 08-30-15, 04:31 PM
SeanO
SeanO's Avatar
I run a 265 on the rear of my IS 350
I'm also lowered on f-sport springs and i don't get any rubbing
Harrisch
08-31-17 06:51 AM
AKAVENOM
12-04-16 03:10 PM
Rane2016
01-24-13 08:56 AM
frotiss
IS F (2008-2014)
09-24-12 04:38 PM
V8Lexus
Wheels, Tires & Brakes Forum
04-23-06 12:04 PM
Quick Reply: stock wheels 265\40\18 ?
