Spark Plugs
Old 02-21-15, 09:13 AM
chris621
chris621's Avatar
Default Spark Plugs
so my cars got a good amount of mileage and was thinking I should probalu change the plugs. at the same time I don't want to cuz the car runs fine and I don't like fixing things that work right. any input? and also how much does lexus charge for labor on changing them. thanks guys
Old 02-21-15, 10:03 AM
355F1
355F1's Avatar
Just quoted $490 yesterday to change the plugs with me having my own parts. Lexus of Chandler.
Old 02-21-15, 10:15 AM
chris621
chris621's Avatar
damn, a little more than I expected :/ anyone else
Old 02-21-15, 10:57 AM
RXISF
RXISF's Avatar
I replaced mine myself at 85k - when I took them out - they definitely appeared to have needed changing. I wouldn't let it go just bc the car runs fine.
Old 02-21-15, 11:13 AM
chris621
chris621's Avatar
how difficult was the instal, I might just ask a friend whose a mechanic. I just hate asking for favors
Old 02-21-15, 11:28 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Do you have an IS250 or IS350? The install is considerably easier on the IS350.
Jeff
Old 02-21-15, 02:56 PM
chris621
chris621's Avatar
Jeff
I have a 250
Old 02-21-15, 04:39 PM
LucianoLee
LucianoLee's Avatar
took me a little over 2 hours for changing the plugs on 250. there is a DIY on here somewhere
Old 03-13-15, 07:05 AM
lax180sx
lax180sx's Avatar
I just did mine 2 days ago using this as a guide. Took me 3 hours. Just take your time https://www.clublexus.com/forums/per...ug-change.html
Old 03-13-15, 08:17 AM
mattmatt57
mattmatt57's Avatar
I just did mine this past sunday. mine is an is350. Install is Really easy especially if you have changed plugs before. Mine only had 40k miles and they looked in bad shape... Just becuase your car isnt misfiring doesnt mean you shouldnt pull the plugs, just like any other maintance, it needs to be done. Install only took me 1 hour max. and Ran much better after.
Old 03-13-15, 05:10 PM
saxqtzk
saxqtzk's Avatar
I did the 250 a few weeks back... not hard if you have patience and the right tools. The only bad part was I accidentally severed a wire behind the intake manifold which caused a bunch of lights to come on. It took me 2 days to find the problem after changing out gaskets everywhere. Just be careful when removing the intake manifold. GL
Old 03-13-15, 05:53 PM
Sffd103
Fire Slayer
Sffd103's Avatar
the manual recommends to change them at 60K. How many miles do you have. It should be done when it recommends.
Old 03-13-15, 08:38 PM
liqB
liqB's Avatar
If you can get the carbon buildup recall done for your 250 (replace piston rings + rebuild) provide the dealer with some sparkplugs, they'll be more than happy to change them for you.
I changed my plugs around 94k and they had all tonnes of crud on them.
2010rouge
04-24-21 04:41 PM
Bocatrip
03-30-15 09:07 PM
ay3333
04-13-14 04:38 PM
LDNN
07-31-12 04:42 PM
amerquresh
07-29-11 07:31 PM
Quick Reply: Spark Plugs
